Hello everybody, please help me!!!
I want to rip the subtitle in a DVD copyright by YesAsia. I did everything as the guide suggest, but it only run up to 94-96% then it STOP. What can I do now?
At first my Subrip window appear exactly like this
As soon as I hit START, this window appear
Source: 1st Pic @ Dvd-Guides.com
thank you for answering me, but is there anyway you can show me step-by-step? I am a newbie here, sorry.
Open the IFO in VobSub Configure (included in VobSub) and take it from there. Here's a guide:
http://www.doom9.org/dvobsub.htm
Once you get the IDX/SUB files, you can try SubRip again (File->Open VOBs->Open Dir), or open the IDX in SubResynch (also comes with VobSub) and then "Save As" SSA or SRT or whatever format you like. -
Thanks manono
I did use the guide you gave me, but at the end I got this message...
mtc,
Try if this helps when using Subrip:
Using the dropdown box near "language streams"; see if there's a "Greek wide letterbox" or "Greek 4:3" entry available.
The important part is the wide/letterbox or pan&scan mentioned in the name of the subtitle stream.
Hope this can be of any help. -
My guess then is that there's something wrong with the DVD on the hard drive. My next suggestion would be to start over and decrypt it again. How did you get it onto the hard drive originally?
Aiwa HV-MX100 display doesn't light up & stop button doesn't work
By TurboJoe in forum Newbie / General discussionsReplies: 15Last Post: 12th Feb 2011, 18:07 -
SubRip doesn't give me option to save srt
By diamondback in forum SubtitleReplies: 7Last Post: 13th Jun 2010, 08:59 -
Subrip and Hard Subbed Video files - does it work?
By Jeremiah58 in forum SubtitleReplies: 3Last Post: 23rd Aug 2008, 10:01 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 05:58 -
SUPER doesn't work
By tedgrant in forum Newbie / General discussionsReplies: 6Last Post: 16th Nov 2007, 14:36
