    Dec 2008
    im trying to convert a movie from xvid to h.264, and when i get to the final step and hit start is just says error. not whats wrong, not why, just error.
    i dont know what im doing wrong, ive been trying to encode this damn thing for a week now. mediacoders crop feature wont work, and megui gives me this unknown error.
    i made a script, cropped it, analyzed it, everything was fine. loaded the script in megui and set my desired bitrate and chose automated 2pass, with turbo checked. it enques fine, but when i press start, it jsut says error.....
    does anyone have any idea whats wrong? ive got k lite codec pack installed so i cant believe it would be anything like that.
    also, it gives the same errors on differerent bitrates, quantizer based, and even on a different video
  2. post the log and your .avs script
    Dec 2008
    OK i fixed it, and made my first sucessful conversion!
    When I open the file with Gspot it doesn't show me any info though, it jsut says its an mkv file, nothing about fps bitrate, nada
    its an x264 encode, nothing special
    anyone know why it may not be showing the details? and how to see them in maybe another proggie?
    Mar 2007
    maybe you should update to the latest version too?
    Dec 2008
    yeah i did, that's what fixed my first problem. that and i reinstalled my codecs
    Mar 2007
    ^ its helpful for others too if you post how you solved the issue..
    how was i to know u updated?
