I keep getting this message when I try to rip the DVD "cant read block 6 (That changes every time) byteposition 12kb unlock again now and retry.
I used the tutorial from this board.
Any help would be great.
localfinesse
try using anouther proggie, vStrip maby.
sometime that helpsWell, I am the slime from your video.
Oozin' along on your livin'room floor. -
Just curious, what DVD are you trying to rip when this heppens?
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
I got the same problem trying to rip Saving Private Ryan. It happens on the same point. The DVD-rom drive begins to choke . I already tried to rip with Smartripper 4 times! No go. Thought the disc was scratch as far as I can see it has no scratches. Anyway I ended up using Decrypter. Clad and Vstrip will also rip the same disc without any problem.
I am using a 16x BTC dvd rom. I am tring to rip stigmata. I errors when I first try to rip it. I used drive info and it says region code : not set. User : 5 changes left. Manufacturer: 4 changes left. Status: not set.
What can I do? I did try Decrypter and the same thin happened. I am running wim 98 if you needed to know.
Sorry I am very new to this
Thanks for your help guyslocalfinesse
tmpgenc authoring 4 + smart rendering problem
By themaster1 in forum Authoring (DVD)Replies: 1Last Post: 3rd Sep 2011, 22:14 -
h264 smart render problem
By wentwog in forum EditingReplies: 2Last Post: 18th Aug 2010, 14:26 -
Audio Error With WinMKV DVD Ripper
By Pitsson in forum DVD RippingReplies: 2Last Post: 2nd Nov 2009, 12:17 -
Menus not shown in DVD Decrypter or Smart Ripper
By EmpireStrikesBack198 in forum DVD RippingReplies: 2Last Post: 11th Jun 2008, 16:48 -
Smart ripper help
By holland11 in forum Authoring (DVD)Replies: 4Last Post: 13th May 2007, 01:15
