Hi.
All you out there who have Toshiba SD1300 DVD player!!!
Please, help your newly born 'brother'.
I just bought this DVD player because they said it would play anything i put in it. I just maid a couple of VCDs and all i see is some jittering and splashes on the screen, and the picture keeps freezing every second.
I followed step-by-step the DIVX to VCD creation guide from vcdhelp. I used TMPGenc with PAL template for VCD creation and then burnt it with VCDEasy. It was easy but the results are not as good as i expected them to be.
Need help badly.
Hi there,
Yes, I have one of those DVD's players; not impressed at the moment. Plays DVD's, VCD's perfectly; SVCD's, good picture only; audio out of sync .... have you made any progress?. Thanks.
Regards,
Joe. -
i've never had a pioneer dvd player before, but i do recommend you to use a different kind of blank cds to burn. get fujifilm, it's a very good brand, dont use cheap bargain cds to burn vcds or svcds. you might want to try burning in a slower speed, like 4 or 8 to see how it turns out. last but not least, make sure you are using a good program for burning, firburner if the format is bin/cue, nero if it's mpeg.
Diffuser home made
By B-Twien Bytes in forum Newbie / General discussionsReplies: 0Last Post: 21st Oct 2009, 05:56 -
Toshiba RD-XS35 won't play some disks
By inferno7 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 12th May 2008, 14:18 -
home made DVDs wont play on all stand alone DVD players. why?
By suomiaussie in forum Authoring (DVD)Replies: 12Last Post: 2nd Jan 2008, 21:59 -
Home made AVI to FLV
By Eibach in forum Video ConversionReplies: 3Last Post: 6th Dec 2007, 15:25 -
can't copy home made dvdr
By pressthe6 in forum Authoring (DVD)Replies: 20Last Post: 29th Nov 2007, 11:35
