Wanted to try my hand at Avisynth scripting and thought of using Avsp first. But the program just refuses to run. It tells me to look at the Avsp.exe.log. And the log file reports following error:
File "run.py", line 5, in <module>
File "AvsP.pyo", line 73, in <module>
File "pyavs.pyo", line 31, in <module>
File "avisynth.pyo", line 4, in <module>
File "ctypes\__init__.pyo", line 415, in __getattr__
File "ctypes\__init__.pyo", line 340, in __init__
WindowsError: [Error 126] The specified module could not be found
I am running XP SP1.
Any help or suggestions will be greatly appreciated.
Thanks.
Results 1 to 13 of 13
Hi I just joined this forum but realise this thread is pretty old! I too tried "today" to use this method to edit mts in PP CS2. I have followed most of the instruction. And wrote a script as shown in the guide in notepad saved it as "file".avs but it would not import as an asset in pp project window? Then I DL avsp and just like you Vidalien, and despite clean and reinstall, get the same error!
Is it because it's too hold - I've got no idea and it seems this does not create much interest either! Still I hope someone coud help.
I'm trying to use file from a jvc everio GZ mh 200 that so far is not very cooperative!
Thanks MM -
Yes I did and now I'm struggling with QT alternative direct show
OMG! AlanHK 2am was going to give up and switch of everything went to bed pretty **** up, then thought of what you asked, came back to the computer and realised I did DL Avisynth and placed it in the adobe folder...But NO i did not installed it! I was pretty happy after installing it to see the ***window at last showing up! Thank again. It's a worry though if I got trouble with this how I'm going to manage the rest....Well it's good night for me! Thank you again
MM -
Well it did not take too long! I tried to import the script in PPro, had to choose "all the file" because the format is not supported and because it is not it won't import? Where do I go from here. I thought the instructions said that it is to be imported like any other asset and shows as a square pixel. I must have miss something more. My scrip is in green and reads: #DirectShowSource"00011.mts"
which is the name of my clips. -
use qtsource (qtinput) for quicktime files , or ffmpegsource, instead of directshowsource
install premiere avs import plugin for premiere pro
http://videoeditorskit.sourceforge.net/
right click and interpret the file in the clip bin, if you don't have square pixel footage. If you have interlaced footage, interpret the field order -
Thank you for that, now I can see my AVS script file in Premiere import window. So I imported one of my script (placed in the same directory as the source files scripted (DirectShowSource”Myfile.avs”) but received a msg from PP2 “I don’t understand DirectShow” ! It still imported a file and it’s icon in the Assets windows was like a normal video and sound file. I could not interpret it and it even disappeared after a while from that window?
I want to import .mts files from my JVC GZ-MH 200 Video Cam. (AVCHD) and the guide for that job says :
“ *You'll also need an AVCHD directshow codec installed. If you don't have one, you can use the latest Qtalternative”
Do you think I still should use a different “****source” for that?
Thank you,
MM -
install haali media splitter, ffdshow
preview your .avs script in vdub, see if there are any error messages
avchd is very slow & sluggish to edit. You need a fast computer. Most people would use a cineform intermediate , or use offline editing (proxy workflow) -
Ouch! I'm back to the original problem. "need a faster pc with more ram!" I have installed Haali media splitter and will try ffdshow
PC won't start No graphics
By jollyjohn in forum ComputerReplies: 19Last Post: 27th Jan 2011, 23:20 -
was working now it won't start
By scoooter1 in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 30th Jun 2009, 00:30 -
Rip won't start
By audax in forum Authoring (DVD)Replies: 3Last Post: 20th Jun 2009, 03:41 -
avisynth- AvsP
By deco81 in forum Newbie / General discussionsReplies: 4Last Post: 29th Dec 2008, 10:39 -
PC won't start
By DuBsTaR in forum ComputerReplies: 8Last Post: 8th Nov 2008, 00:11
