I have been getting a message while using Adobe Premiere CS3 with my Matrox Axio LE system. I notice it more in longer projects or any project that has been open for a long period of time during the day. A small bubble will pop up at the near the matrox logo that says Adobe Premiere Pro Memory usage is extremely high please save you project and shut down the program. If I don't shut it down the program eventually crashes. But this seems to be coming up quite frequently does anyone know if there is a way to configure your system so this message doesn't occur as frequently?
That sounds like a memory leak. See if there's an update or fix to Premiere
explorer.exe high memory usage while trying to load ass/ssa subtitles
By Nightroad in forum SubtitleReplies: 2Last Post: 17th Jan 2012, 17:36 -
need help solving excess memory usage in video capture
By philfr in forum Newbie / General discussionsReplies: 6Last Post: 10th Jan 2011, 18:47 -
memory usage of CUDA encoding
By sharkbite in forum Video ConversionReplies: 0Last Post: 25th May 2010, 22:36 -
Extremely low burn speeds, High CPU usage
By BetaMaster in forum Authoring (DVD)Replies: 13Last Post: 20th Nov 2008, 12:23 -
VPS server or high usage shared host?
By thecoalman in forum ComputerReplies: 0Last Post: 9th Nov 2007, 00:17
