is it possible to cut between keyframes?
Yes, if you re-encode around the cut point to restore the keyframes. A program like the newest VirtualDub can do 'smart rendering' and let you cut where you want. But I don't know if it will work with your format. Other editors may be able to do this also. Or if you re-encode the whole file, the keyframes should be restored.
I just ordered a magicjack and was wondering if anyone else used one
By johns0 in forum Off topicReplies: 9Last Post: 4th Oct 2010, 02:46 -
Was wondering if such a thing exists....WAN (Wireless USB connector)
By SE14man in forum Newbie / General discussionsReplies: 4Last Post: 3rd Oct 2010, 04:53 -
left wondering ... which capture device ?
By hydra3333 in forum Capturing and VCRReplies: 4Last Post: 2nd Dec 2009, 03:23 -
Just wondering why h.264 support in mobilephones is a NO-NO in the US
By bacardi/avt in forum Portable VideoReplies: 10Last Post: 2nd Nov 2008, 14:58 -
Wondering how to capture a visual output from one computer on another
By StarBeam in forum Capturing and VCRReplies: 0Last Post: 23rd Jun 2007, 19:53
