I currently use autoGK to convert my VOB anime files to avi and i burn the subtitles. BUT the only issue is that it takes forever to convert! so i downloaded the cinema plugin for the archos 7. The VOB files transfer and play on the archos (with both audio tracks) with no issues. But i cant seem to access the subtitles. Do i need another application to separate the subs? Someone please help!
I don't think so but have you searched in http://forum.archosfans.com/ ?.
But converting to avi xvid shouldn't take that long on your computer. Use one-pass quality encoding and try lower the video resolution a bit. -
thanks for reply. yes i did join archosfans and i posted the same question. i will only do one pass this time like you said.
one more question. how can i convert a mpeg from 848x480 to 720x480. the reason is the max resolution on the archos is 720
[Archos 605] transform from 720p.HD.DVDRip.XviD.AC3 to Archos format ?
By birdwing in forum Portable VideoReplies: 2Last Post: 5th Nov 2009, 23:41 -
Extract subtitles from VOB files
By webstar in forum MacReplies: 9Last Post: 29th May 2009, 15:34 -
Burn VOB files with included Subtitles
By psyget in forum ffmpegX general discussionReplies: 1Last Post: 24th Jun 2008, 17:49 -
Nero Recode for mpg and vob to avi for Archos
By drstew in forum Portable VideoReplies: 3Last Post: 30th Sep 2007, 09:55 -
Archos 404 & DVR stand vs Archos AV 500 - difference in MPEG-4 recordin
By DavidMcGowan in forum Capturing and VCRReplies: 0Last Post: 4th Aug 2007, 05:49
