Hi
Can anybody maybe help with this as i am unsure why the video is producing this odd edges (looks like thin black lines), is this artifacts? Why? and how can i correct it (Editor Vegas 8, original footage - Panasonic GS400)
Below is an image capture showing the odd edges especially around the 2 white pillars and around the guys head; (It also appears in the final rendered video so is not an image capture problem)
http://www.flexids.org/why/odd.jpg
Sure it must be something i'm doing wrong, any help would be greatly appreaciated
It's interlaced video. It is perfectly normal for video. Each frame of video contains two separate half-pictures, one in all the even numbered scanlines, one in all the odd numbered scanlines, intended to be viewed one at a time on TV:
Your computer displays both at the same time unless you are using a deinterlacing player.
If you are making DVDs ignore it (don't resize or crop the frame), it will display properly on your TV. If you are uploading video to youtube (or similar) you want to deinterlace. -
AAa ok thanks, how stupid of me lol, i should have known that
Thanks jagabo
rougher edges than in the original...
By Weef in forum Video ConversionReplies: 55Last Post: 17th Aug 2010, 12:19 -
blurred edges
By mathmax in forum RestorationReplies: 50Last Post: 2nd Jun 2010, 10:22 -
Noise around the edges.
By MaiOns in forum Newbie / General discussionsReplies: 8Last Post: 14th Mar 2010, 10:52 -
Question why edges cuts off
By tofuguy in forum Authoring (DVD)Replies: 2Last Post: 26th Oct 2008, 02:09 -
Procoder 2 - Jagged Edges
By pbar in forum Video ConversionReplies: 4Last Post: 24th May 2007, 09:32
