When trying to open in Media Player Classic a divx container created with AVIAddXSubs I get the following message from Avi Chunk Viewer: "This AVI file was not prepared for sequential reading, the alternative 'Avi Splitter' will now let the default one handle it. The complete reinterleaving of this file is strongly recommended before burning onto a slow media like cd-rom." Can this problem be corrected without reinterleaving?
No. But reinterleaving will only take a minute. Open with VirtualDub, select Video -> Direct Stream Copy. Save. It may not retain subtitles though. Or in AviDemux open the file then save it.
Mpeg4Modifier appears to retain the subtitle track (you can still see it in a chunk viewer) but Divx Player won't display them. And MPCHC still gives the Avi chunk viewer error so it doesn't solve the problem. I think MPC just gets confused by the subtitle stream.
My understanding is that subs in .divx container only work with divx ultra certified products (i.e. no software)
If you want subs inside a container, use .mp4 or .mkv; otherwise keep them outside with .avi container -
They work with Divx Player. But, yes, they don't play in MPC, VLC, etc.Originally Posted by poisondeathray
Good to know. I don't have that installed. (and I never willOriginally Posted by jagabo
change an MKV container to AVI container???
By Spdngblt56 in forum Newbie / General discussionsReplies: 10Last Post: 17th May 2010, 21:23 -
Problem while converting MP4 container into avi
By Fire Foxer in forum Video ConversionReplies: 4Last Post: 29th Nov 2009, 15:55 -
Flash like Divx container?
By homer_3 in forum Video Streaming DownloadingReplies: 3Last Post: 14th Jul 2008, 12:27 -
Divx (avi container) issues, jittery playback
By adam1972 in forum Blu-ray RippingReplies: 1Last Post: 19th Jun 2008, 18:46 -
How do you move files from .ogm container to .mkv container?
By VidHunter in forum MacReplies: 0Last Post: 8th Mar 2008, 18:19
