I get this error when I try to open some vob's in DGindex. This started happening since I updated DGindex to 1.5.3, tried both "Demux Tracks" and "Demux All Tracks" in the audio output method, but none worked. What should I do to fix this issue?
Just checked with 1.5.0 and it has the same problem, seems to be working fine when making a d2v and demuxing the audio track (File\Save Project) in both 1.5.0 and 1.5.3
AnonymousGuest
You say it works when doing Save Project. When does it NOT work? Demuxing only happens if you do Save Project.
Note that "Demux Audio-Only Stream" is intended only for streams WITHOUT video.
I see that the Users Manual does not explicitly state that the audio is demuxed when you do Save Project.
I'll fix that for the next release.
It doesn't work when demuxing the track only, yes I know that it does not save the video by that method, I chose it because the d2v was created, but the AC3 did not appear
AnonymousGuest
Again, I don't know what you are saying because you aren't using the terminology of the program.
"When demuxing the track only" ... what does that mean? What menu operation?
If you don't get your audio when you do "Save Project", then you have not configured it properly. Read the users manual carefully. Things have changed in the audio ID specification since 1.5.0.
How to demux .avi file with multiple audio tracks?
By junglemike in forum AudioReplies: 8Last Post: 26th Oct 2012, 19:05 -
Open source TS mux/demux tool
By rrrip in forum Video ConversionReplies: 1Last Post: 28th Jan 2012, 10:39 -
I have a .mpg file that I need to demux I want the audio..
By J Tinsby in forum Video ConversionReplies: 6Last Post: 23rd Jun 2011, 19:20 -
DGIndex command-line demux audio only
By Mark001 in forum Video ConversionReplies: 4Last Post: 25th Nov 2009, 14:19 -
no DGIndex timestamp while saving project file
By ecc in forum DVD RippingReplies: 1Last Post: 22nd Dec 2007, 14:38
