I'm going to buy a camcorder to film some stuff that I need on my computer, which I will edit on my own.
High Definition is NOT necessary.
I don't have a capture card. I don't have Firewire.
Just a regular Windows XP, 3.4 ghz computer with USB ports.
What camcorder technology will make some decent looking movies and is EASY to transfer to PC (considering the things I don't have on my PC)?
Thanks!
Budget? At what quality? You have two basic choices.Originally Posted by Xenogear900
Get a good quality camcorder (e.g. Canon MiniDV) and an IEEE-1394 card (PCI or PC card).
Get a lower quality SD MPeg2 cam that can transfer with proprietary drivers over USB and software that can edit the result.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I actually have a Panasonic Mini-DV camera.
How do I get the tapes onto the PC?
WITHOUT FIREWIRE. -
You *might* be able to use USB to get low resolution (320 x 240 - ish) heavily compressed video.
If you want the best possible quality, you need to use firewire.
If you are happy with lower quality, you can get a cheap, USB based analogue capture system, and use the composite output from the camera.
Of you can hook the camera up to a DVD recorder, record the video and use DVD to transfer it to the PC.
Again, if quality is even remotely important, firewire is your only option.Read my blog here.
http://www.pinnaclesys.com/PublicSite/us/Products/Consumer+Products/Home+Video/Studio+...version+12.htm
Itīs USB (altough for DV transfer you connect your camera via firewire cable) and you donīt need an internal firewire card -
if you want to use miniDV buy a $20 firewire card and install it. that's how it's done. otherwise don't whine about not being able to transfer it to the computer. -
Is this a desktop? laptop?
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&Description=IEEE%2D1394%20pc...nd&Order=PRICE
Laptop with no PC Card slot?
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&Description=video%20capture%...nd&Order=PRICERecommends: Kiva.org - Loans that change lives.
easiest sw to transfer an original DVD to my portable computer
By marlo in forum Newbie / General discussionsReplies: 3Last Post: 28th Sep 2010, 02:53 -
What is the easiest way to transfer blu-ray to something like mkv?
By hannibal1 in forum Blu-ray RippingReplies: 11Last Post: 24th Aug 2010, 20:57 -
Video transfer from camcorder to PC
By tony_baruti in forum Capturing and VCRReplies: 6Last Post: 25th Nov 2009, 12:33 -
transfer from camcorder to computer
By stratman in forum Newbie / General discussionsReplies: 4Last Post: 29th Sep 2008, 11:07 -
16:9 transfer via Panasonice 4:3 camcorder
By wozmac in forum Capturing and VCRReplies: 4Last Post: 22nd Apr 2008, 16:27
