I'm having trouble with my certain 4 disc bin/cue file i got. It won't play on my SONY DVD player. I burned it as a SVCD I believe. It says on the screen something like "13.00" - i think it had some letter before it too. Anyways - this DVD player has never had trouble playing regular VCD's in it. And I've played this certain 4 disc bin/cue successfully in my friends portable DVD player with no problems. So, I know that the burn was alright.
If anyone could tell me where I can go from here to make this work it would be greatly appreciated. If it means I have to convert it from Bin/Cue to just VCD I guess I'll do that - but I'd rather find a way to play it as a SVCD as I've heard the quality is much better.
Also, this is the first SVCD I've tried in this particular DVD player - so does that mean that no SVCD will work in this DVD player?
Thanks.
correct.. in general sony DVD players don't play SVCD.
(some models do.. very few though) -
check out this site m8 http://www.geocities.com/newestmoviesencode/dvdvcd
i have a sony dvp-s336 and was unable to play svcd until i tries this and now i am burning near dvd quality svcd,still have to use cd-rw though,will try princo silver when i can find them,hope this helps you out -
Windy,
When I convented my svcd to vcd, the pictures only displayed a part of the original pictrures of svcd on TV. Did you change your svcd's frame size? Or you also used 480x480 svcd templete in TMPGEnc? Thanks in advance!
Sony S370 Blu-Ray player not playing subtitles from USB
By nfurlong in forum SubtitleReplies: 2Last Post: 31st Jan 2012, 08:20 -
issues playing burned DVD's on sony blu ray player bdp-s300
By cdcutlip in forum DVD & Blu-ray PlayersReplies: 2Last Post: 7th May 2011, 16:12 -
Is it worth changing HDD over to FAT for playing on Sony Blu Ray player
By Dankriss in forum DVD & Blu-ray PlayersReplies: 11Last Post: 17th Jul 2010, 20:40 -
Trouble with SONY DVD+R disc and SONY player/recorder
By Winston99 in forum Newbie / General discussionsReplies: 3Last Post: 29th Mar 2010, 23:54 -
Playing region free DVD on Sony SR200P DVD Player
By merik in forum DVD & Blu-ray PlayersReplies: 5Last Post: 25th Nov 2009, 16:35
