I created a mpg slideshow to burn to a DVD using TMPGencXP. I did not like the final soundtrack, and would like to replace it with an mp3 track that I have. However, I belatedly found that mp3 format does not work in TMPGenc DVD Author. What format should I best use, and what program will do the conversion of my mp3 track? (I read some old postings here, and found that the BeSweet program produces AAC files that are not fully compliant with some DVD players, so that seems to be out.)
Thanks for any help,
Rhett
I think you mean AC3, not AAC. Yes, reportedly some Pioneer DVD players don't play nice with BeSweet's AC3 output, but I've not tested this myself. I've not encountered problems with BeSweet's output.Originally Posted by rdfarr
Another option, if you feel the need to avoid BeSweet for some reason, is to encode into MP2. Although not strictly spec-compliant in the US, I have never found a modern DVD player that won't play MP2 without a complaint. Authoring tools will accept DVD video with MP2 audio. So that's another possibility for you. -
OK. I used BeSweet with BeLight and had a successful coding to DVD volumes.
Not related to the audio, I'm not too pleased with the video results of my slideshow from TMPEgencXP. Next time I'll look for a different video encoder. I had started off with Nero but it could not handle the 1400 pictures.
Thanks for the help.
Rhett
Replace about 50 frames of video in an .mpg file (keep audio the same)?
By gastrof in forum Newbie / General discussionsReplies: 6Last Post: 19th Jul 2011, 23:29 -
How to combine video with audio file and replace audio with video files ?
By designbuyers in forum Newbie / General discussionsReplies: 2Last Post: 8th Feb 2009, 12:12 -
Best way to replace an Audio Track on x264 Video Movies...
By erosoft in forum Blu-ray RippingReplies: 2Last Post: 4th Dec 2008, 10:25 -
Freeware to replace audio track on a video file?
By gastrof in forum Newbie / General discussionsReplies: 2Last Post: 2nd Jun 2008, 22:54 -
how to replace an audio track to a music video and getting it to synch
By alarmsman in forum AudioReplies: 1Last Post: 20th Jun 2007, 15:06
