Hello.
I formatted my Windows XP and I reinstalled the programs.
Now, when using the guide of Ryan ( http://www.ryan.com.br/virtualdub_en.htm ) in the window VirtualDub-Video-Fast recompression-Compression does't appear the option Xvid or Divx Codec.
How must I proceed to obtained these lines to select the respective codec?
Thank you very much.
Cheers.
I had installed ffdshow as you said before and I thought it had the codecs in question.
But now with your xvid codec and divx codec, the problem is resolved.
I have another problem : the original file has 664MB and the new one has 460MB. How can I force the new one to have the same length to have better quality?
Thank you, Baldrick, once more for your always desired helps
Cheers.
Common Codecs and xVid / DivX compatability
By anonymous_whatever in forum Newbie / General discussionsReplies: 25Last Post: 20th Feb 2012, 17:53 -
Multiple Divx codecs?
By Huh...What? in forum Video ConversionReplies: 15Last Post: 16th Dec 2009, 08:44 -
How to reinstall the codecs? (K-lite, XVID, etc.)
By dzsoul in forum Newbie / General discussionsReplies: 3Last Post: 19th Mar 2009, 05:08 -
Useful to feed MeGUI-xvid/264 (or codecs in general) full-size frames?
By chconnor in forum Video ConversionReplies: 2Last Post: 29th Jul 2008, 16:28 -
Xvid Quantizer Codecs
By theninger in forum Video ConversionReplies: 3Last Post: 25th Jul 2008, 10:54
