hey i'm new here i was wondering how to play my blu ray from my laptop to my tv, i have a blu ray drive and a hdmi cord but it wont let me play it to my tv please help![]()
PLEASE PLEASE PLEASE give us more information.
Do you see the windows desktop on your tv? Have you tried change any display driver settings like dual or clone view?
What blu-ray software player are you using?
Do you get any error message playing the blu-ray?
etc...
And this is not any Blu-ray backup problem. Moving you. -
Sorry should of added more info but I can see my computer screen on the tv and see it on my laptop so it said it was in mirror mode but its kind of cut off around the edges on my tv, the player I am useing is hp quick player, when it gets to the movie it says this disc is protected and cannot be ran under this display setting, but if I unplug the hdmi cord it will play on my laptop
It sounds like HDCP protection(see http://en.wikipedia.org/wiki/Hdcp ). You could try install anydvd hd(trial available) and it will remove the hdcp. You could also try change display settings so the hdmi is the primary display or is the only output(no dual or clone mode) and see if it make any difference.
Ok cool I got that working just 2 more questions where is the setting where I can run the dvd while my laptop is closed also the edges on the tv is still cut a little on the sides any idea on that
Usually you can go under your screen saver settings and then power management and adjust what your computer does when you close your laptop (on XP Pro it is the Advanced Tab under Power Options). There is a setting there "When I close the lid of my portable computer:" and my options are Do Nothing, Stand By or Hibernate. You want to set it to Do Nothing. This should allow you to run your laptop with the lid closed and use your TV as monitor. You will need an external keyboard and mouse.Originally Posted by celecon
Jason
Mpeg-4 stutter freeze on laptop 1, laptop 2 plays fine- why?
By sevenofone in forum Software PlayingReplies: 1Last Post: 8th Apr 2011, 16:15 -
Formatting laptop, how do i know if a laptop has wifi capabilities?
By ricardouk in forum ComputerReplies: 8Last Post: 21st Nov 2008, 09:24 -
DVDs work in desktop PC but not in laptop - previously worked in laptop
By Brent Jewell in forum Newbie / General discussionsReplies: 3Last Post: 6th Nov 2008, 19:40 -
using second laptop as a video in from laptop with broken display
By joycefitz in forum Newbie / General discussionsReplies: 4Last Post: 18th May 2008, 23:56 -
Got my first laptop PC
By Barlow in forum ComputerReplies: 11Last Post: 1st Feb 2008, 02:21
