Hello all,Are there any studio lights that can be adjusted to vary the amount of light?Lights whereby you can diminish or increase the amount of light.And if there are,could you please recommend a model of that light.Thank you.,Linda
BIG topic but yes most pro lights are on dimmers.
The prime issue for cheap dimmers and lights is to maintain color temperature as dimmers are adjusted. Be sure to use manual white balance after dimming lights.
Most photo equipment stores (pro stores not Ritz Camera) and pro AV rental shops can help you with a lighting package.
If you are on the cheap, a good adjustable camcorder can get good results when tweaked using normal house light dimmers. I like the wide spectrum GE "Reveal" bulbs when on the cheap.
For a serious project, I rent lighting equipment.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Limiting the amount of zooming After Effects is doing during stabilization?
By kingmustard123 in forum EditingReplies: 3Last Post: 3rd Jul 2011, 11:12 -
Question about Lynksys NAS200 and moving large amount of data to it.
By nzdreamer55 in forum ComputerReplies: 0Last Post: 9th Sep 2010, 10:09 -
Adjusting vobsubs for new AR?
By Xavier in forum SubtitleReplies: 1Last Post: 4th Mar 2009, 12:41 -
What is the smallest amount of change in color that the eye can detect ?
By Movie-Maker in forum Newbie / General discussionsReplies: 8Last Post: 6th Dec 2008, 11:41 -
Toshiba RD-XS35 producing a relatively high amount of bad/weird burns
By Bix in forum DVD & Blu-ray RecordersReplies: 14Last Post: 23rd Sep 2008, 12:25
