Hi, Im hoping this shoul be an easy open and shut thread.
I have a made a video file m2v and 5 audio tracks for this video, and I would like to author it into DVD, the combined file size is 6.2GB I need it into 2xDVD5s and also containing all of the audios( I usually use Womble Mpeg Wizard DVD and this only allows me to add one audio track).
Any tips would be awsome thanks![]()
you'll need a pro type authoring program like dvdlab pro. it allows up to 8 audio tracks. i'd probably make it into a dvd9 in dvdlab and then use dvdshrink to re-author it into 2 dvd5s.
DVDFab (Commercial version) or DVD Remake Pro
Read my blog here.
Do what? Split it after authoring, keeping the menus? VobBlanker (free):Hoever any names of software that could do it including menus??
http://jsoto.posunplugged.com/guides/VobBlanker/splitdvd9/index.php -
You can use MuxMan with GfD, but as GfD supports only 3 audio streams directly, you need to tweak the control file a little bit (just post a note if you are interested). Concerning the menus, there is nearly no limitation. But menus on a 'split' DVD are not that helpful. If you select audio stream #3 on the first DVD from the menu, the player will not 'remember' it and start with the default audio stream, if you insert the second part DVD...
GUI for dvdauthor:
https://www.videohelp.com/~gfd/
6.6GB mpeg2 onto a standard DVD?
By cheesypuffs in forum Newbie / General discussionsReplies: 15Last Post: 18th Jun 2011, 11:32 -
AVStoDVD crashed on audio encoding.. have m2v video file, but no audio
By arcooke in forum Newbie / General discussionsReplies: 3Last Post: 5th Aug 2010, 15:18 -
How can I take 6GB content to fit into 4GB DVD?
By Han Solo1 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Mar 2010, 14:20 -
4.9GB Vid + 2.1GB Aud = 8.6GB?!?!?
By BurkettC in forum Authoring (Blu-ray)Replies: 6Last Post: 10th Jul 2009, 19:43 -
PS3 not streaming AVI >6GB (Open-DML) with DTS Audio
By Alterego in forum Video ConversionReplies: 7Last Post: 24th Jun 2008, 08:51
