It was working with Windows XP, but now does not with Vista X64. I downloaded the latest drivers from Nvidia but that did not help. I then downloaded the drivers from Asus, specific to my card, also did not work. There is no option in the Nvidia control panel to enable DVI. Any suggestions?
Shut down the computer (not sleep, or hibernate). Attach the monitor to the DVI port. Turn on the monitor. Turn on the the computer. The graphics drivers should see the monitor and enable the output.
Does your card have two DVI outputs? Try the other. -
Thanks. Tried it several times and it did not work. Uninstalled the Nvidia drivers, restarted the computer, and got a picture off DVI! The Vista downloaded the driver and it's working well now.
PC to Plasma HD TV with DVI Input Question (Nvidia 8800GT Video Card).
By Infinite_Dreamz in forum Newbie / General discussionsReplies: 5Last Post: 2nd Oct 2011, 09:28 -
Cant get either video capture card to work
By ralphey in forum Capturing and VCRReplies: 1Last Post: 6th Aug 2011, 21:02 -
Plug DVI/HDMI adapter to DVI video card?
By Stealth3si in forum Media Center PC / MediaCentersReplies: 25Last Post: 23rd Dec 2010, 20:32 -
Hardware advice, video card & monitor, DVI or VGA ??
By Noahtuck in forum ComputerReplies: 7Last Post: 12th Jul 2009, 01:58 -
DVI doesn't work but VGA does
By JPMcG in forum ComputerReplies: 2Last Post: 6th Jun 2009, 10:49
