Hi,
Actually I record my signal tv with mencoder
ex: mencoder tv://$channel_number -ovc lavc -lavcopts
vcodec=mpeg4:vbitrate=$VBITRATE:vhq:keyint=100 -oac mp3lame -lameopts
vbr=0 -o OUT_PATH/NAME.avi
I would like to do the same but I would like to generate a mpg file not and avi file. How could I do this??
Many thanks and sorry for my english!
Using Mencoder, I've never been able to capture anything but blank frames in windows. I can't seem to set the tuner options properly and unfortunately for me, the defaults are low resolution pal and I live in NTSC land.
Try using vcodec=mpeg2video. I was able to capture blank frames with that and Gspot says that it's an mpg2 file. You'll probably want to change the audio codec also depending on your end use.There's not much to do but then I can't do much anyway.
photo capture from video signal hardware
By huegel in forum Capturing and VCRReplies: 0Last Post: 6th Mar 2012, 09:50 -
Do capture cards clean the signal ?
By davexnet in forum Capturing and VCRReplies: 18Last Post: 29th May 2010, 20:45 -
How to capture still images from video using mencoder?
By kkol123 in forum Video ConversionReplies: 4Last Post: 26th Nov 2009, 04:00 -
Capture video signal from a camera to a laptop
By Cazz in forum Capturing and VCRReplies: 4Last Post: 15th Feb 2009, 15:17 -
URGENT: Capture signal is black on Dazzle DVC170
By Exavior in forum Capturing and VCRReplies: 0Last Post: 7th Jul 2007, 20:47
