I'm trying to get video I recorded on a miniDV onto my computer. It's an older camcorder, nearly 10 years old, and what's worse, I don't have my USB to DV in/out cord. But I do have one of those AV cables that has the three plugs on one end and the other end looks like a little power drill. I also have a Dazzle DV-Bridge, which I plugged the AV cable into, with the other end going into my camcorder (JVC GR-DVL505). Finally, the Dazzle is connected via firewire to my Powerbook G4, running iMovie 6.0.3 on OSX 10.4.11. Unfortunately, attempts to upload the video from the camera to the computer have only brought up a "No Device Control" screen.
To sum up, I have:
JVC GR-DVL505 camcorder
PowerBook G4 laptop
Mac OSX 10.4.11
iMovie HD 6.0.3
Firewire
A/V cable
Dazzle DV-Bridge
Will any combination of those things get my video from the tape to the laptop?
welcome to the forum here!
only 1 thing is needed. just use a firewire cable. that's it. plug it into the camera and the computer and transfer the tape that way. miniDV can only be captured that way. -
there's no firewire port on the camera though. Not that I can see, anyway. It has a spot for AV, DV IN/OUT, and S Video.
Your camcorder doesn't have a firewire port,the DV-Bridge should work but it sounds like you have a driver conflict.
According to the manual, you do have a firewire port on your camcorder, itīs referred as the "DV port" (like Sonyīs i.link) and you should find it right under the AV port and above the S-video one. The cable is not the same that goes into the USB port under the LCD screen, thatīd be only adecuate for transfering stills, so donīt worry about the missing one that came with the cam, just get a regular 4 to 6 firewire cable.
http://www.retrevo.com/support/JVC-GR-DVL505U-Camcorders-manual/id/209dj898/t/2/ -
Originally Posted by generic_screenname
4 pin
http://www.fixya.com/support/p398483-jvc_gr_dvl505_mini_dv_digital_camcorder/manual-16844/page-44
Edit:
Little late -
Originally Posted by julitomg
I'm curious about the possibility of driver issues, since the bridge looks like it should work, but it isn't.
does this work
By sve in forum TestReplies: 7Last Post: 21st Apr 2012, 22:15 -
how do I install x264.exe to work AND to work with Lemings GUI?
By Krelmaneck in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2010, 22:13 -
Does not work.. What can i do?
By schr2004 in forum ffmpegX general discussionReplies: 0Last Post: 24th Jul 2010, 15:21 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 16:11 -
How much do you work? (work = doing something you are getting paid for)
By Baldrick in forum PollsReplies: 20Last Post: 26th Nov 2007, 15:35
