Hi all.
I have been using my capture card for capturing my ps2 for some time, now i have changed to a xbox 360 system and i seem to have some problems.
At PAL-50 everything works ok, but when i try to change to PAL-60 i see everything in black and white and with a lot of noise.
I hope someone here could help with this or show me where to find help.
Here are my specifications:
Avertv hybrid+fm volar usb A828
driver v1.7.0.88
averTV-Video v6.0.12
I have tryed other playing softwares with same result
intel core2 t2400
3gb ram
ati movility radeon x1400
Will apreciate any idea, i am totally out of em :P thank you.
I had similar problem while checking how my Xbox360 would deal with my capture device. Try to switch Xbox to proper PAL format in "system settings" and pick NTSC433 instead PAL-60 in your capture client ( in my case PAL-60 didn't work at all ). Also don't forget to pick proper frame size ( in my case this could be only 720x480 ). I hope this will help.
AverTV USB HD DVR or Hauppauge USB HD PVR
By gll99 in forum Capturing and VCRReplies: 34Last Post: 8th Jun 2015, 10:56 -
Recording from USB AVerTV TwinStar
By MrJiriM in forum DVB / IPTVReplies: 1Last Post: 27th Feb 2012, 21:34 -
AVerTV Hybrid Volar HX digital recording problems
By TO MOYTRO in forum Capturing and VCRReplies: 7Last Post: 15th Jan 2011, 08:36 -
Capturing Pal60 With Easycap DC60
By e0turnerl in forum Capturing and VCRReplies: 4Last Post: 21st Mar 2009, 12:07 -
AVerMedia AVerTV Hybrid Volar HX capturing
By kiraly.andras in forum Capturing and VCRReplies: 1Last Post: 13th Sep 2008, 14:17
but didn't help
