Major problems with any 23.97 FPS DivX avi's being converted when using TMPG DVD Author 3.
Any ideas how to rectify this?
I've tried manual settings, specifying to re-encode at 24FPS and 25FPS to no avail.
Every second or so there is a judder during playback of the Vob files - not evident in the original AVI file.
Any advice would be much appreciated.
Thanks.
Is this an option in TMPG DVD Author?
I'm not seeing it if is it.
I've read about re-encoding with VobSub.
Is there any app that does this all together rather than having to use multiple applications to achieve the conversion successfully?
Thanks. -
Most all-in-one type video conversion programs convert frame rate by simply duplicating or discarding frames. This creates periodic jerks in the video (24 to 25 fps will get one jerk every second, 24 to 30 will get 6 jerks per second, etc).
Most 25 fps PAL DVDs are created from 24 fps film by speeding up the frame rate -- the equivalent of running the projector faster ~4 percent faster. That will require that you do the same with the audio. -
I would suggest one of two things
1. Don't bother. The vast majority of PAL players will also happily play NTSC videos, so conversion is not necessary in most cases.
2. If you must convert, use a tool that converts using the pulldown method. This means the video will be encoded at it's original framerate, and some electronic trickery will be performed at playback time to get the correct framerate. FAVC or DVD Flick can do this.
Personally, I favor option 1.Read my blog here.
As already mentioned, the problem may come from internal TMPG encoder's simplified settings (addition of full frames instead of pulldown). A possible workaround is feeding your file to TDA3 via AviSynth script:
TDA3 is also capable of making menu backgrounds from .avs.Code:AviSource("video.avi") ChangeFPS(60000,1001)#or ChangeFPS(50) for PAL DoubleWeave().SelectEvery(4,1) # hard pulldown
Best framerate conversion? (eg: 23.97 to 30 fps to avoid judder)
By ionone in forum Video ConversionReplies: 16Last Post: 12th Mar 2014, 08:56 -
What causes judder and what can be done about it?
By drstew12 in forum DVD & Blu-ray PlayersReplies: 19Last Post: 27th Nov 2013, 20:33 -
judder in Hauppage HD PVR sourced discs
By daj38 in forum Authoring (Blu-ray)Replies: 4Last Post: 3rd May 2011, 17:46 -
Output file is a mess - judder & interlaced....
By The.King in forum Video ConversionReplies: 6Last Post: 29th Jan 2011, 22:44 -
mkv to dvd camera judder on pan
By paulh129 in forum Video ConversionReplies: 12Last Post: 23rd May 2010, 14:38
