HI,
I'M SORRY IF I HAVE POSTED MY QUESTION ON THE WRONG FORUM.
I WOULD LIKE TO CONVERT MY AVCHD FILES TO THE BEST POSSIBLE QUALITY FORMAT.
I WILL BE USING COREL DVD COPY WHICH CAME ALONG WITH MY VIDEOSTUDIO PRO X2.
THERE ARE QUITE A CHOICE OF FORMATS AND I AM UNSURE AS THE BEST OPTION.I EVENTUALLY WANT TO MAKE A PAL DVD FOR USE ON A DVD PLAYER TO VIEW ON TV.
ANY ADVICE WOULD BE MOST APPRECIATED,
SULLIVEN.
Results 1 to 10 of 10
Then you choice is quite limited: MPEG2, 720x576, 25 fps.Originally Posted by sulliven
MPeg2 is required for a universally playable DVD It also must be 720x576 or 704x576 standard definition.
See: What is DVD? above
https://www.videohelp.com/dvdRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Hello,
Thanks a lot for your prompt replies edDV & jagabo.
I just wondered if there was a different format as I'd never used AVCHD before.
Well many thanx for the answer to my question....not much room for error there.
All the best and thanx for your time,
Sulliven. -
Alternative is Blu-Ray but playback would require a Blu-Ray player.
Other alternatives exist for computer playback.Recommends: Kiva.org - Loans that change lives.
Hi,
Thanks again edDV much appreciated your help.
I have Blu-Ray on my computer so I may try it just to compare the difference in quality.
I originally thought there might be a better quality to MPEG-2 with AVCHD but not to worry.
I am still very much a beginner but then you probably noticed that already lol.
All the best and thanx again.
Sulliven. -
AVCHD was designed for compression to flash media as first goal. Quality is not up to HDV currently but may improve in the future. Problem is each camcorder is locked in hardware to the time of product introduction. There are no performance updates for hardware based codecs.Originally Posted by sullivenRecommends: Kiva.org - Loans that change lives.
Hi,
I tried converting my AVCHD to Mpeg2 - 720x576 which it did no problem.
The problem was the video was being stretched from top to bottom making things taller than they really were.
I apologise if it something simple or stupid but I have very little or no experience with AVCHD.
I was using the Corel DVD Copy 6 to convert the files.
Yours Sincerly,
Sulliven -
If you look at 16:9 "wide" 720x576 on a square pixel monitor it will appear horizontally squished. That is normal. If the file is flagged as wide, the DVD player will stretch it back out wide for playback at the selected resolution.Originally Posted by sulliven
SD Wide = 1024x576
720p = 1280x720
1080i = 1920x1080
If you set the DVD player to SD letterbox, the image will be vertically rescaled.Recommends: Kiva.org - Loans that change lives.
Hi edDV,
Thanx once again for your advice and time it is much appreciated.
I am sure it will all come together sooner or later, it's always the same when I change things.
I shall return to my project tommorrow thaks again for your info.
Cheers,
Sulliven.
AVCHD on hard drive: creating new AVCHD folder structure
By Phil_W in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 1st May 2011, 14:46 -
AVCHD from SD-60
By domyue in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 4th Dec 2010, 14:02 -
software to batch convert m2ts format avchd to mts avchd?
By masterpug in forum Video ConversionReplies: 0Last Post: 14th Aug 2010, 01:06 -
.TS AVCHD to anything!!!
By digital-mann in forum Video ConversionReplies: 3Last Post: 22nd Jan 2009, 09:16 -
Avchd
By eric11111 in forum Authoring (Blu-ray)Replies: 1Last Post: 11th Dec 2008, 15:35
