Hello!
I have been using this command line to cut a piece of .avi xvid and convert it to .flv format (from a terminal in mac os x or on freebsd server)
Everything was working like a charm! But sometime ago, i started getting 0Kb converted .flv files for like 80% of the movies i'm working on. I'm pretty sure that i haven't changed anything on my system, probably some new codec is used in those xvid avisCode:for f in *.avi; do mencoder -forceidx -lavfopts i_certify_that_my_video_stream_does_not_use_b_frames -of lavf -ss 00:10:00 -endpos 00:02:10 -ffourcc FLV1 -oac mp3lame -lameopts abr:br=56 -srate 22050 -ovc lavc -lavcopts vcodec=flv:turbo:vbitrate=425:mbd=2:mv0:trell:v4mv:cbp:last_pred=3 -vf scale=480:320 $f -o done/$f.flv ; done
this is what i see in terminal
Please help! I think i need to change something in my command or try ffmpeg instead of mencoder, but i don't know the correct command string for ffmpegCode:brandox:400plus brandox$ for f in *.avi; do mencoder -forceidx -lavfopts i_certify_that_my_video_stream_does_not_use_b_frames -of lavf -ss 00:18:00 -endpos 00:02:10 -ffourcc FLV1 -oac mp3lame -lameopts abr:br=56 -srate 22050 -ovc lavc -lavcopts vcodec=flv:turbo:vbitrate=425:mbd=2:mv0:trell:v4mv:cbp:last_pred=3 -vf scale=480:320 $f -o done/$f.flv ; doneMEncoder dev-CVS-060307-04:23-4.0.1 (C) 2000-2006 MPlayer TeamMac OSX static build for ffmpegX CPU: Intel (Family: 6, Stepping: 6) FIXME:Hardenabling SSE and SSE2 without detection CPUflags: Type: 6 MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1 Compiled for x86 CPU with extensions: MMX MMX2 SSE SSE2 success: format: 0 data: 0x0 - 0x195c9706 AVI file format detected. AVI: Generated index table for 148654 chunks! VIDEO: [XVID] 640x480 12bpp 30.303 fps 1568.0 kbps (191.4 kbyte/s) [V] filefmt:3 fourcc:0x44495658 size:640x480 fps:30.30 ftime:=0.0330 ========================================================================== Opening audio decoder: [mp3lib] MPEG layer-2, layer-3 AUDIO: 48000 Hz, 2 ch, s16le, 32.0 kbit/2.08% (ratio: 4000->192000) Selected audio codec: [mp3] afm: mp3lib (mp3lib MPEG layer-2, layer-3) ========================================================================== ** MUXER_LAVF ***************************************************************** You have certified that your video stream does not contain B frames. REMEMBER: MEncoder's libavformat muxing is presently broken and will generate INCORRECT files in the presence of B frames. Moreover, due to bugs MPlayer will play these INCORRECT files as if nothing were wrong! ******************************************************************************* OK, exit Opening video filter: [expand osd=1] Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1 Opening video filter: [scale w=480 h=320] ========================================================================== Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family Selected video codec: [ffodivx] vfm: ffmpeg (FFmpeg MPEG-4) ========================================================================== Forcing output fourcc to 31564c46 [FLV1] MP3 audio selected Pos: 0.0s 1f (52%) 0.00fps Trem: 0min 0mb A-V:0.000 [0:0] 1 duplicate frame(s)! VIDEO CODEC ID: 22 AUDIO CODEC ID: 15001, TAG: 0 Writing header... [flv @ 0x896170]dimensions not set Floating point exception MEncoder dev-CVS-060307-04:23-4.0.1 (C) 2000-2006 MPlayer Team Mac OSX static build for ffmpegX CPU: Intel (Family: 6, Stepping: 6) FIXME:Hardenabling SSE and SSE2 without detection CPUflags: Type: 6 MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1 Compiled for x86 CPU with extensions: MMX MMX2 SSE SSE2 success: format: 0 data: 0x0 - 0x1fe50bc6 AVI file format detected. AVI: Generated index table for 185771 chunks! VIDEO: [XVID] 640x480 12bpp 30.303 fps 1577.9 kbps (192.6 kbyte/s) [V] filefmt:3 fourcc:0x44495658 size:640x480 fps:30.30 ftime:=0.0330 ========================================================================== Opening audio decoder: [mp3lib] MPEG layer-2, layer-3 AUDIO: 48000 Hz, 2 ch, s16le, 32.0 kbit/2.08% (ratio: 4000->192000) Selected audio codec: [mp3] afm: mp3lib (mp3lib MPEG layer-2, layer-3) ========================================================================== ** MUXER_LAVF ***************************************************************** You have certified that your video stream does not contain B frames. REMEMBER: MEncoder's libavformat muxing is presently broken and will generate INCORRECT files in the presence of B frames. Moreover, due to bugs MPlayer will play these INCORRECT files as if nothing were wrong! ******************************************************************************* OK, exit Opening video filter: [expand osd=1] Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1 Opening video filter: [scale w=480 h=320] ========================================================================== Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family Selected video codec: [ffodivx] vfm: ffmpeg (FFmpeg MPEG-4) ========================================================================== Forcing output fourcc to 31564c46 [FLV1] MP3 audio selected Pos: 0.0s 1f (41%) 0.00fps Trem: 0min 0mb A-V:0.000 [0:0] 1 duplicate frame(s)! VIDEO CODEC ID: 22 AUDIO CODEC ID: 15001, TAG: 0 Writing header... [flv @ 0x896170]dimensions not set Floating point exception MEncoder dev-CVS-060307-04:23-4.0.1 (C) 2000-2006 MPlayer Team Mac OSX static build for ffmpegX CPU: Intel (Family: 6, Stepping: 6) FIXME:Hardenabling SSE and SSE2 without detection CPUflags: Type: 6 MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1 Compiled for x86 CPU with extensions: MMX MMX2 SSE SSE2 success: format: 0 data: 0x0 - 0x1dc0782a AVI file format detected. ^Znerating Index: 71 % [1]+ Stopped mencoder -forceidx -lavfopts i_certify_that_my_video_stream_does_not_use_b_frames -of lavf -ss 00:18:00 -endpos 00:02:10 -ffourcc FLV1 -oac mp3lame -lameopts abr:br=56 -srate 22050 -ovc lavc -lavcopts vcodec=flv:turbo:vbitrate=425:mbd=2:mv0:trell:v4mv:cbp:last_pred=3 -vf scale=480:320 $f -o done/$f.flv brandox:400plus brandox$
				Results 1 to 1 of 1
  How to convert MKV to AVI or OGM to AVI using mencoderBy Baldrick in forum User guidesReplies: 75Last Post: 17th Dec 2013, 12:19
  .avi -> .flv with embedded subtitles using MENCODERBy the_provider in forum Video ConversionReplies: 0Last Post: 28th Oct 2009, 17:38
  Movie Clip Will Not Convert from .flv to .avi - Pazera Free FLV to AVIBy videoelfone in forum Video ConversionReplies: 3Last Post: 21st Jun 2008, 01:14
  Mux a FLV AVI + MP3 -> FLV with ffmpeg or mencoder?By Colmino in forum Video ConversionReplies: 9Last Post: 29th Mar 2008, 23:11
  AVI to FLV using mencoderBy Riotblade in forum Video ConversionReplies: 11Last Post: 13th Feb 2008, 13:00
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
