I've been converting my HD-DVD's to BlueRay mostly with TSmuxer and Ripbot. It has gone well,I've converted some movies to two disk sets on DVD+R DL when the two EVO files are each under 8GB's and they play well on my Sony S350. Other movies I've compressed with Ripbot to a single DVD+R DL and they have played well.
The problem I'm now running into is on episode disks. I'm trying to convert Star Trek TOS season one from HD-DVD to BlueRay,putting each episode on a DVD+R DL disk. I used my normal TSmuxer method but the disks stutter severly on my S350. I compressed an episode with Ripbot to a DVD-R and it plays well on my S350. Is stuttering an indication of a framerate problem? I note that the Star Trek HD-DVD's are 29.97 and the compressed DVD-R is 23.97.
Could this be the problem? I had a similar problem when I tried to backup the Firefly series from BlueRay disks.
Remove the pulldown with vc1conv.
http://www.glenharrison.com/bluray/Regards,
Rob -
Thanks for the link. The guide didn't work but it pointed me to the H264info program and after a little trial and error I got it fix my problem. I needed to remove pulldown to get the Star Trek disks to convert without stuttering. They used AVC encode instead the normal VC-1 you find on HD-DVD's. Remove pulldown reset them from 29.96 to 23.976 but did not result in audio synch problems. Thanks again. I should have read your comment to "remove pulldown" instead of following the guide.
Add DVD Subtitles to a BlueRay
By wulf109 in forum Blu-ray RippingReplies: 3Last Post: 16th Mar 2014, 18:53 -
What's on the horizon? Is Blueray likely to replace dvd?
By Haopengyou in forum Newbie / General discussionsReplies: 1Last Post: 1st Jun 2010, 14:27 -
SD DVD Played on Blueray Player
By wulf109 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 17th Aug 2009, 09:36 -
mkv to blueray on dvd 5
By Greg6721 in forum Authoring (Blu-ray)Replies: 3Last Post: 25th Jan 2009, 12:40 -
How Do I rip HD DVD and BlueRay?
By alexv305 in forum Newbie / General discussionsReplies: 1Last Post: 7th May 2008, 10:31
