  1. was using to capture on windows xp and everything goes right.
    i moved to windows vista and now i having a problem.
    i am using virtualdub with picvideo 3 for compression.
    all the setting are the same from what i have on XP.
    well, when i try to capture, almost anything i do on my computer result in frames droped\inserted and even if i'm not doing anything, it still give me sync problem.
    i found some solution that i untick the "enable desktop composition" from the visual effect of vista.
    it seems better now but playing any video on vlc look crappy now and get a preview of what i am capturing on virtualdub looks crappy too.
    2 things:
    1. on WMP any video looks fine although the "enable desktop composition" is untick.
    2. crappy means that the video looks pixelate and the software (virtualdub\VLC) not smoothing it.
    i would be thankful for your answers.
  2. Banned
    New York, US
    Vista! . Shoulda stayed with XP. I needed a new PC but could only find Vista junk out there. So I went to newegg.com and tigerdirect, picked up a copy of XP Pro OEM, and built my own. No problems. I lugged the Vista PC back to the store the morning after I bought it. If you expect you'll keep traveling with Vista, be prepared for a long, tough haul.
  3. well, i can understand you but i really think its just some configuration because vista works great on this pc.
