Everytime I open the video converting program SUPER, I get this:
				Results 1 to 12 of 12
	This problem has been around awhile. If you downloaded the program through the links at: https://www.videohelp.com/tools/SUPER sources and not some other source, there's no trojans, just a bad read by your antivirus program. Super accesses some parts of the computer software that some malware programs flag as malware. It's not.
 If you can set your antivirus to ignore or pass on the malware scan, that's one way. Otherwise, you might look for another anti-malware program.
 I only use SUPER occasionaly. It's not that great of program, just a bunch of freeware programs bundled together. If you have a specific conversion in mind, there are other programs that may be a better choice. Programs that try to 'do it all' are usually a poor choice for specific conversions. If you have a specific conversion in mind, there are other programs that may be a better choice. Programs that try to 'do it all' are usually a poor choice for specific conversions.
	I downloaded SUPER at its author's site www.erightsoft.com. So ur saying that this trojan isn't a trojan? But then wat's that file it detected in Local Settings/Temp/zcodecs/s2m4.dll?Originally Posted by redwudz
 I'll have to ask my mom. I'm only 16 years old lol, I have no idea wat I'm messing with here =POriginally Posted by redwudz
 Not that great?! Dude, SUPER is by far the best converting program I have ever used, and I've tried about 30 or more converting programs, so I should know. The fact that it's free and it works is all that I'm worried about. I spent months searching for a free converter that wont corrupt my videos, and SUPER is the only one I could find for .mov to a format supportable by Windows Media Player and Windows Movie Maker.Originally Posted by redwudz
	It's called a false positive. The virus scanner thinks it recognizes virus code within the file(s), or what it thinks may be virus-like activity, but it isn't. That's also why I recommended you make sure your McAfee scanner is completely up-to-date (both program and virus definitions), in the other post.
 I don't see a lot of people recommending McAfee for virus scanning these days, though. If you're in doubt, you can always have a site like www.virustotal.com check the files - they use several scanners all at once, not just one.If cameras add ten pounds, why would people want to eat them?
	If it says Trojan why take a chance, uninstall and delete it, run full antivirus also go to http://housecall.trendmicro.com run a secondary antivirus make sure it is cleaned out then download it from this forum's link.
	Have you tried the free Prism converter from http://www.nchsoftware.com/prism/index.html?gclid=CKXwheS5nZgCFQKJxgodriAimg. Super failed to convert some videos from url links which Prism converted very easily. Try Prism to see if it does what you want and see if the false trojan warning is eliminated.
	Quick media converter 3.60 does a great job, but the new verion 3.65 seems to be very buggy. Give the older version a try.
	The link from this forum still gives me the virus, so it's probly within the program or something. I think it is a false positive tho, and as long as MacAfee keeps quarentining it, I doubt it should ever affect me.Originally Posted by INFRATOM
 Well we've had great luck with MacAfee. It catches viruses all the time, does updates everyday, it's a great program. It also came with my computer, so that's wat we use. We don't really trust any other not-well known virus scanner. We do trust ones like AVG, MacAfee, or comcast stuff, u know wat I mean?Originally Posted by Ai Haibara
 I have already done that like 5 times. The trojan still gets detected despite removing it 100% and scanning. It will always be there, but as long as MacAfee is quarentinin it, I should be fine. And besides, I got like 5 different ppl telling me it's a false positive.Originally Posted by INFRATOM
 I don't care about url link conversions. I never need to do that. SUPER works awesome for me and as long as it follows my commands, I'm not switching converters.Originally Posted by bevills1
 I'm not leaving SUPER just cuz there's a trojan that ppl r telling me is wrong, PLUS it's being quarentined each time. As long as SUPER runs and everything is good, then I'll continue to use SUPER.Originally Posted by LBJ
	Norton, AVG and other have methods of how to remove certain Trojan, not all can be removed just by scanning because some are hiding as partial downloader and will bring in and assemble the trojan again. Super doesn't have virus your copy does, it must be a modified one that you downloaded from a questionable site. When you run virus scan when you have infection you must turn off system restore so they just don't come back. It is up to you to clean out your computer or not, %35 of computers are zombies meaning they have hidden infection and they are woken up at certain time by the hacker. There are some books on the subject if you like to read. The Super from this forum's link does not have virus I have installed it.
	I just downloaded it from the forum's link, but it still gives me the same exact trojan........Originally Posted by INFRATOM
	If one of SUPER's components is being quarantined, that means nothing can use or access that file - not even SUPER. So, SUPER may technically not be running properly, or be able to convert properly, as one of its components is 'missing.'
 If you want to be sure (and McAfee actually lets you do anything with the file(s) in question ), you can always upload it/them to www.virustotal.com, and see what results they give you.
						If cameras add ten pounds, why would people want to eat them? ), you can always upload it/them to www.virustotal.com, and see what results they give you.
	Well I wouldn't worry about it cuz it does function properly. I'll only do those things u said once it starts acting all weird. I'll try scanning it with that site real quick tho.Originally Posted by Ai Haibara
 Edit: I uploaded SUPER.exe to the scanner thing and here's the link to it:
 http://www.virustotal.com/analisis/9c37d8c5cd29613e8cccdf9ae0ed461f
  Trojan Horse Downloader in Super???By Slowburn in forum ComputerReplies: 13Last Post: 18th Aug 2012, 23:00
  SUPER v2011 Build 48 Contains a Trojan !!!By Djard in forum Newbie / General discussionsReplies: 6Last Post: 11th Jun 2011, 16:19
  What is AVI(for pocket PC) in Super?and keep aspect ratio in Super ?By SingSing in forum Video ConversionReplies: 2Last Post: 19th Dec 2009, 22:05
  is Erightsoft's SUPER a Trojan?By mister_to_you in forum Video ConversionReplies: 4Last Post: 13th Jun 2008, 03:30
  Why does SUPER take so long to start?By StratPlaya in forum Video ConversionReplies: 8Last Post: 25th Aug 2007, 12:29
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
