  1. I couldnt find the exact thread for my problem, so here goes, sorry mods. I have been using dvd decrypter for several years without a hic up and its a great program, my problem as of late is i can not use it anymore to burn my movies, i first put the original movie thru dvd shrink and then proceed to burn with dvd decrypter, but it has stopped working and i have run out of options, i have tried almost everything, when it comes up it says: DEVICE NOT READY/ MEDIUM NOT PRESENT>>> INSTEAD OF READY. if anyone has an answer for me it would be greatly appreciatted.
    dr strange
  2. Man of Steel freebird73717's Avatar
    Dec 2003
    Smallville, USA
    Well for starters you could start by using updated software. Dvd decrypter hasn't been updated in a long time.
    Use DVDfabhddecrypter for getting the movie to your hard drive.
    Dvdshrink is old but is still functional for shrinking movies. Also look at dvdrebuilder.
    When ready to burn use Imgburn (created by the author of dvddecrypter but much more updated -- however without decrypting capabilities hence the above suggestion for ripper).
    But honestly I doubt if your problem is with dvddecrypter. My guess is that your burner is going south... or could be some other hardware problem.
    Try imgburn to see if that solves your problem but if it doesn't I think you have bigger problems.
    ps. You might ask a mod to move this thread to another forum as this question really doesn't belong in the VCDeasy forum.
    Also "Welcome to our forums"!
    Donadagohvi (Cherokee for "Until we meet again")
  3. Thanks freebird, i appreciate you taking the time to answer my questions, i looked for the appropriate thread and didnt find it. I am taking your advice and downloading the programs you mentioned.
    The doc
  4. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    The doc
    Look harder....
    DVD to DVDR Forum,
    3rd sticky down....
    I can't rip with DVD Shrink or DVD Decrypter
    You'd have to be blind to miss it 8)
  5. Sorry, i wrote a response to noah, but i am not going to stoop to his level. Thanks again freebird. And noah, if you checked before saying something, you would of noticed that that thread is locked out.thank you anyway, you were such a great help.
    the doc
  6. Banned
    Jun 2004
    Careful noob 8)
    Its not for posting, it's for READING & LEARNING that YOU are using WAY outdated software
    They have been putting out copy protections on DVD's that defeat DVD Decrypter & shrink for oh say... 2 years now
    What freebird said or a few other things but we should not have to drag every bit of info out of you, you should be posting as much info as possible.
    And if what i wrote was so offensive, you need to get a grip
