Results 1 to 9 of 9
    Jan 2009
    Can anyone recommend a free downloadable software thats easy to use, that does the same thing as DVD shrink?
    The reason I ask is because I've been using DVD shrink, but the movies burn onto disc a data, and I'd like to try a different programme.
  2. ReJig. Then burn with ImgBurn.
    Pull! Bang! Darn!
  3. Member yoda313's Avatar
    Jun 2004
    The Animus
    It should give you everything you need to make a regular dvd. Do you have the "make video_ts folder" option selected? Also you could select an iso image as your output file. That would contain your entire dvd structure. Then you can burn that with any disc burning utility that supports the iso format (which is all of them as far as I know).
    Check these screens out for dvd shrink 3.1 (I believe that was the final version released):
    That will either give you a video_ts folder that when burned as a root directory on the dvd will behave exactly as the original or you can choose iso. Iso will pack the video_ts folder into a .iso file that can be burned with a cd burning program that supports iso and make it like a real dvd.
  4. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Then you are doing something wrong.
    Jan 2009
    Yeah. Everything here that you have shown is the exact way I've done it. Except I'm not too sure how to select the iso option. I've got the movie in a folder, and it has all the releative files in there when I open it.
    I've tried to use the burn movies option in my burning studio. It say as long the folder has VOB, IFO, and BUP files then it can be done. I've checked this and all folders are fine, and do contain the required files. I then add the folder to be burned onto a dvd, and click the NEXT tab to proceed, Then I just get a message box on the screen informing me that "folder doesn't contain valid DVD files".
    I'm no expert when it comes to this, but in theory this should work????? Can you tell me what I'm doing wrong, or what is going wrong?
    I can burn the dvd from the files section in my burning studio (it writes as data though) and it works perfectly on all my dvd players, but won't play on a PC.
  6. Member classfour's Avatar
    The Heartland, United States
    Install Windows Media Player Classic (or the Home Cinema version) which is free - unless you have a valid DVD player and DVD-ROM (or -R -RW etc) drive, you will not be able to play the disc. I assume that since you're burning with the machine, the drive is correct.
    ;/ l ,[____], Its a Jeep thing,
    l---L---o||||||o- you wouldn't understand.
    (.)_) (.)_)-----)_) "Only In A Jeep"
  7. Member Seeker47's Avatar
    Jul 2005
    The final version was 3.2.15. (There was also a modded version that could optionally call ImgBurn for the burning, I believe, but that version requires at least Win XP, due to a DLL issue.) Some strongly recommend the use of ImgBurn for burning, anyway -- over Shrink's own burning engine -- and it would be a must with D/L media for other reasons.
    If Shrink is properly set up, and there is no hardware or media problem going on, it pretty much has to work. I don't recall ever burning in data-file format with it. Not even sure how I could do that deliberately.
    Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com
  8. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Shrink does not, and never did have it's own burning engine. It has the ability to create an ISO file or HDD folders, or to use the burning engines from DVD Decrypter, Nero (certain versions) or CopytoDVD. The modded version also supported Imgburn. If you didn't have any of these installed, DVD Shrink would not burn.
    Read my blog here.
