I've tried several times to burn a project using Premier Elements but when I get to 85% I'm getting a transcoding error, does anyone know what that is and how to fix the problem.
I tried rendering the footage and that worked ok with no problems I'm using Video footage and dubbed music over the top for the majority of the project, the error message is "Transcoding error" and it is coming up at the same position of the "encoding media" step
When I render is that rendering the hole movie project or just the start..?? -
I think I might have fixed the problem, I deleted a slide show of some photo's and the DVD burnt without a problem. Thanks Gunslinger for taking the time to answer my question..
Help burning Pinnacle project to DVD...mpg, converting, etc.
By jubbilee in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2011, 14:37 -
"Dirty disk" problem after burning. PLS HELP!
By mlo2102 in forum Authoring (DVD)Replies: 9Last Post: 29th Jun 2011, 15:17 -
Editing a project in HD, but burning to DVD in SD...
By Huntr777 in forum MacReplies: 6Last Post: 14th Jun 2011, 20:20 -
Problem burning a project on to a DVD from TMPGEnc Author 3
By vhsal in forum Authoring (DVD)Replies: 5Last Post: 21st May 2011, 18:25 -
Burning iso image from Hard disk to hard disk?
By When in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2008, 22:27
