Can anyone tell me how I can place a video clip on my DVD disk to play before the chapter main menu shows up? I have all the chapters ready but there is a intro that I would like to ad to play before the option of the chapters is displayed. Alot like when you watch a movie and the 21st Century Fox logo apears and then the main menu is displayed.
I'm using Nero Vision 4.
Cheers
cp_ozie![]()
Results 1 to 12 of 12
If Nerovision can do it, you will be looking for something most likely called Firstplay. However, as Nerovision is more of a toy than an authoring tool, you may not be able to do it unless you either find a real authoring application, or you create you disc in NV4, then use PGCEdit to add the firstplay item in after the fact.
Read my blog here.
Fairly self-explanatory, don't you think? If you have a specific question about some step you don't understand, then ask it. PGCEdit can be pretty intimidating and to learn it thoroughly takes time and effort, but what you want to do with it is pretty simple.Originally Posted by manono
Most authoring programs have the ability to add a start-up clip. -
I installed Ulead Video Studio 11 and it has the lot. Thanks for you efforts.Originally Posted by manono
I finally got this to work.
Was testing the result by opening the .iso from Pgcedit with VLC.
It went straight to the menu each time.
When I burned the iso to disk and played it back on the standalone - it played the clip then went to the menu.
I note that there is a sizable delay between the end of the clip and the appearance of the menu.
Is this inherent in DVD playback? -
Check the post command for the start-up clip. The ones I've done go straight and quickly to the menu after playing the intro clip. If yours does the same, then the delay you're experiencing has something to do with your player, I would guess. If there's some other stuff you removed that once played before the menu (things like studio logos, trailers and the like), then the delay can't be helped, unless you learn how to jump over them and go straight to the menu. That kind of thing can also be done using PGCEdit, but may take some practice to learn. The first thing worth learning would be how to work the Trace so you can follow the commands as they work their way through the DVD.
Thank you for responding.
The main movie is a simple clip, with a menu created by DVD Flick.
I tested it with different standalone players with the same result - a ten second delay from the end of the first play clip until the menu appears.
I shall study the trace command - I have attached an image from Pgcedit.
[/img]
Hehe, I'll happily take the credit for pointing you in the right direction but, honestly, the thought never occurred to me that was the reason. Good going for figuring it out. I think I've discovered where the process went wrong and the reason I've never run across your problem:
When adding in animated (motion) First-Play clips, tick the "Don't pause: it's an animated clip" line instead, before hitting "Continue". That 10 second (or however long you set it) pause is for still screens.
Trying to add a small intro clip to a movie file without re-encoding
By solar2504 in forum Video ConversionReplies: 11Last Post: 19th Mar 2008, 10:19 -
By solar2504 in forum Authoring (VCD/SVCD)Replies: 1Last Post: 18th Mar 2008, 02:53 -
Ripped DVDs to Zen Vision M - how to add chapters?
By tmh in forum Portable VideoReplies: 0Last Post: 18th Feb 2008, 22:09 -
What is the easiest method to add intro clip on DIVX ?
By rob3rtz in forum Newbie / General discussionsReplies: 3Last Post: 7th Oct 2007, 05:35 -
Chapters using Nero Vision?
By aelfheah in forum Authoring (DVD)Replies: 4Last Post: 8th Jun 2007, 12:40
