I know you format a DVD before recording but I am new to dual layer DVDs. I can't find info to tell me if you format the latter and if so how it is done?
DVD+RW and DVD-RW and DVD-RAM ... are formated to be used in a table top DVD Recorder ... but a Dual Layer DVD ... uh uh.
http://en.wikipedia.org/wiki/Dual_layer#Dual_layer_recording
http://club.cdfreaks.com/f34/dvd-dual-layer-rewritable-material-222749/
You may have got confused and heard Dual Layer DVD Format .... and thought you were hearing / seeing ... format Dual Layer DVDs.
The Dual Layer DVDs I use are made my Verbatim and I have used also Ritek Ridata ... no formatting involved. Just put one in your burner ... in your PC and use the software you trust to burn it correctly ... Imgburn ... is what I hear alot of people use. It's the Layer Break in Dual Layer DVDs that can be picky and get messed up if not done right.
I also use ... Cyberlink Power2Go and Cyberlink PowerDVD Copy. So far they play just fine.
If Dual Layer Rewritable DVD disks exist ... then maybe they would be formatted ... but they would be expensive -
Thanks to Lacywest for the reply. Yes I think I was getting confused. I didn't think it should be that difficult to find instructions.
Actually contrary to what you believe newer dvd recorders do not need to format any disc (except possibly dvd-ram) before recording to it.. merely erasing previously written- to discs.*. your discs may need to be finalised tho AFTER recording.
*dvd+/-R cannot of course be erased
Hard drives need formatting, and packet writing software needs to format re-writable discs on a pCCorned beef is now made to a higher standard than at any time in history.
what made you ask the question, were you having problems reording to such discs?
PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS
how are dual layer dvds read?
By dblake2 in forum DVD & Blu-ray PlayersReplies: 10Last Post: 6th Jul 2012, 12:51 -
Ok, best tool for converting dual layer dvds to single layer dvds is?
By burgkev in forum Authoring (DVD)Replies: 5Last Post: 25th Aug 2008, 02:02 -
dual layer recording
By flezar in forum Newbie / General discussionsReplies: 3Last Post: 29th May 2008, 15:57 -
Recording on a Dual Layer DVD 8x
By Avto in forum Newbie / General discussionsReplies: 3Last Post: 16th Nov 2007, 13:55 -
what dual layer dvds should I be using with the following setup?
By transient_today in forum MacReplies: 1Last Post: 22nd Jul 2007, 16:05
