I downloaded a movie from the internet which was an avi file. I used AVI2DVD to convert the avi to dvd files. I burned using ImgBurn. The burned DVD works perfectly on my computer and older Pansonic DVD Player. But on the Blue-ray player it does not. Its out of syn and at times scenes have no audio and near the beginning the video paused on its own even though the counter showed the movie continuing ? The Blue-ray player works perfectly on a few Blue-ray disc we have tried and no problems with backed up DVD-R movies either.
Anyone have any ideas or suggestions ?
Memorex is usually among the worst rated media.
Try Verbatim and see if the results improve.
That may not be your problem, but changing media brands is about the cheapest and easiest change you can make. If it doesn't work, then there are other things to try. -
It's been a while since AVi2DVD (and it's various components) has been updated. HCenc for one is now up to .24 (AVi2DVD uses .17).Originally Posted by justmehere
Might be time to move up to a more current app.
Try this one (free):
http://avstodvd.googlepages.com/home
It's in active development and the author responds to questions here.
SONY BDP S185 Blue ray player
By Ahmtas in forum DVD & Blu-ray PlayersReplies: 2Last Post: 19th Nov 2011, 20:00 -
Sony BDP-S350
By mrscat in forum DVD & Blu-ray PlayersReplies: 2Last Post: 25th Jan 2010, 15:12 -
Region-Free hack for Sony BDP-S350 Player
By Megagab99 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 23rd May 2009, 06:14 -
Sony BDP-S350 only gives B/W picture
By masquerain in forum Newbie / General discussionsReplies: 2Last Post: 4th Nov 2008, 15:58 -
Blu Ray Sony BDP-S350
By dreyko in forum DVD & Blu-ray PlayersReplies: 4Last Post: 7th Oct 2008, 14:24
