Hello...My brother have this equipment:
logitech Z-5500
soundblaster x-fi platinum fatality champion series
(conected with a standalone dvd)
windows xp sp2,power 400w
intel 965lt core 2 duo 1.80gh
3.5 gb ram
80gb sata-1
and I have another pc (mine) in a contiguous room...every time that I plug my PC (also when I disconnect my PC) the sound of my brother's PC (with the logitech ) have a drop out in the sound...that drop out delay 1 second aprox.
this happen when my bro work with a coaxial connection,but when he have their equipment in 6-channel direct connection the drop-out don't happen.
Please,someone knows why happen this? would be a cable problem? or would be the electric instalation ?
Thanks in advance.
Shared power line source ... both systems are connected to a line which comes from a single fuse in the power box ... find one that is not "paired" and try again.
Could be your system is first inline for power, and his is last ... your system is causing a minor disruption to power on the line... try switching systems around and see if that problem disappears ... if it dose, then you know how to solve the problem.
Bit like having a pc burning a cd/dvd ... and on the other side of wall sharing same line is washing machine ... it kicks in, burnt disc is toast ... things happen, lol
Please help, im hopeless and dunno where to begin making dvd from video cli
By wendydoncon in forum Authoring (DVD)Replies: 3Last Post: 24th Mar 2012, 10:49 -
Logitech Z5500 > Logitech Z906?
By Stealth3si in forum ComputerReplies: 2Last Post: 9th Nov 2011, 21:10 -
Logitech Revue $99
By MJA in forum Off topicReplies: 0Last Post: 31st Jul 2011, 12:52 -
DUnno where to post this but since this is audio forum...
By faramith in forum AudioReplies: 4Last Post: 28th Jun 2007, 01:40 -
Logitech MX1000
By mccoady in forum ComputerReplies: 1Last Post: 23rd May 2007, 12:34
