Hello Guys (and girls)
Well i have a big problem with videos downloaded from a site http://www.youtubeislam.com i use either flashgot or simply retrieve them from the TEMP but in any case the file appears like corrupted any of my tools can open it tmpgenc,avidemux,Cut Assistant.... help please this drives me made.
it gives me this
Code:General Complete name : D:\Documents and Settings\Administrator\Desktop\ShareIslam_Video_Site___85_year_old_new_muslim_with_Yusuf_Estes_5422.flv Format : Flash Video File size : 182 MiB Duration : 28mn 23s Overall bit rate : 895 Kbps Tagged date : UTC 2009-01-17 17:38:21 Tagging application : inlet media FLVTool2 v1.0.6 - http://www.inlet-media.de/flvtool2 Video Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L3.0 Format settings, CABAC : Yes Format settings, ReFrames : 3 frames Muxing mode : Container profile=Unknown@3.0 Duration : 28mn 23s Bit rate : 787 Kbps Width : 630 pixels Height : 350 pixels Display aspect ratio : 16/9 Frame rate : 30.000 fps Resolution : 24 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.119 Stream size : 160 MiB (88%) Audio Format : AAC Format/Info : Advanced Audio Codec Format version : Version 4 Format profile : LC Format settings, SBR : No Duration : 28mn 23s Bit rate : 99.3 Kbps Channel(s) : 2 channels Channel positions : L R Sampling rate : 44.1 KHz Resolution : 16 bits Stream size : 20.9 MiB (12%)
it's like Chinese to me can you please give more help.
Yep, it's AVC/h264 video in a FLV file and most converters does not support it. Try latest WinFF. Or try use FLV Extract and then open the h264 video in avidemux. See also https://forum.videohelp.com/topic359060.html?highlight=flv%20h264
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 18:28 -
Corrupted MTS FILE problem
By SkyShazad in forum Video ConversionReplies: 10Last Post: 14th Dec 2011, 11:08 -
mp4 file corrupted. Very important file. Need some help!
By seanloughry in forum Newbie / General discussionsReplies: 2Last Post: 5th Dec 2011, 17:54 -
corrupted dv file
By marshs in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 5th Aug 2008, 17:40 -
Corrupted vob file(s)
By Mållgan in forum Authoring (DVD)Replies: 6Last Post: 9th Aug 2007, 08:25
I'll do it right now. thanks
