What soft for convert mov to DVD-movie with support :
acept ratio
auto crop tool
and other advanced option
I used "WinAVI Video Converter" for above, but create a video based pulldown and when I import vob file that created by "WinAVI Video Converter" in "DVD-Lab Pro" for merging & reencoding with another vob files; but after it, that vob file doesn't work well.
I need another soft for convert mov to dvd. Isn't there it?
If you are using dvd-lab pro then convert to mpg/mpeg2 in your converter instead. And when you join different videos in dvd-lab pro they must have identical settings, if not then be sure to use separate tracks/VTS.
You can also try convert your mov to mpg using avidemux, xvid4psp,super,winff.
.MOV conversion to .AVI and .MOV HD quality query
By Peewitisland in forum Newbie / General discussionsReplies: 3Last Post: 31st May 2011, 11:22 -
.mov to DVD
By Tofudog in forum Newbie / General discussionsReplies: 2Last Post: 26th Sep 2010, 22:47 -
How to convert a 1.83 GB .mov to 1000 MB .mov?
By moiz in forum Newbie / General discussionsReplies: 6Last Post: 31st Mar 2010, 15:31 -
mencoder wont convert the complete file, mov to avi|mov
By bjornieB in forum Video ConversionReplies: 2Last Post: 19th Nov 2009, 07:42 -
MOV to DVD
By darogo in forum ffmpegX general discussionReplies: 9Last Post: 26th Apr 2008, 11:09
