Hi Guys:
This is my first visit here. Hope somebody will reply on my question. I have downloaded the movie files from UTORRENT.com and after I have completed the download the video file is on .CBR file format.
Is there any converter for this kind of file?
Thank you and I hope I have posted my inquiry on the right forum. I seem to be lost inside this website. You have a huge topics here.
Good day!
	Are you sure it is a movie ?
 .cbr is usually used for comic books that have been scanned as sperate jpeg files, then zipped into a single archive with the CBR extension. These can then be viewed with something like CDisplay ( http://www.geocities.com/davidayton/CDisplay ) or Jomic ( http://jomic.sourceforge.net/ )
 The only way to convert this file to a video would be to unzip it, then use something like photostory to put all the still pages into a video format.Read my blog here.
	Hi:
 Thank you very big for your reply. I think it was a movie file. I have downloaded that file from TORRENT. System says DOWNLOAD COMPLETE. When i clicked it and played it with WINDOWS MOVIE PLAYER CLASSIC, message was "UNABLE TO READ". But this procedure works PERFECTLY on my friends PC. After the download, video will run smoothly.
 Hayyyyy! Anyway, thank you Boss for the reply. I guess I will have to go back using LIMEWIRE for the movies and other stuff!
 Bye bye!
  Convert audio file og WMV HD videoBy karebo in forum AudioReplies: 2Last Post: 27th Aug 2011, 10:15
  Cannot convert 7.5 GB mkv file to wmv?By killazys in forum Video ConversionReplies: 1Last Post: 17th Feb 2010, 20:07
  failure to convert flv to Avi file because of unsupported video codecBy 2thvideo in forum ffmpegX general discussionReplies: 10Last Post: 30th Jan 2009, 13:54
  wmv file wont play nor convertBy excitezone in forum Newbie / General discussionsReplies: 7Last Post: 18th Dec 2007, 13:56
  Convert divx vbr to cbr audio - video freezes (possible reason & solutiBy lingyi in forum AudioReplies: 0Last Post: 4th Oct 2007, 16:51
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
