I am having the strangest problem, I cannot get the TV to see either of my panny VCR's on RF CHannel 3 or 4,
Work fine otherwise, the rf input from cable scans and records fine.
I would believe it was a fault but 2 machines, am I being stupid and missing something-thanks
PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
How are they connected? And are they directly connected or do you have something between them?
Google is your Friend -
no, direct co-ax from vcr to tv, tried channel 3 or 4 and using rca as ouput proved that the channel in is working and used the aut tune, once I found out the output co-ax wasn;t working.
There is no option in the menu to disable it either.
Many thanksPAL/NTSC problem solver.
VCR comparison Panasonic NV-FS200(AG 1980) VS Panasonic NV-HS1000
By JoseD in forum RestorationReplies: 32Last Post: 18th Apr 2016, 09:30 -
VCR/VHS playback - lines on picture...vcr alignment problem or no?
By daysaf00 in forum Capturing and VCRReplies: 1Last Post: 23rd Jan 2012, 01:54 -
I would like to buy a VCR S-VHS Panasonic...can someone suggest me which of
By Giasan in forum RestorationReplies: 2Last Post: 12th Nov 2011, 17:50 -
Panasonic PV-HD1000 D-VHS VCR - Anyone have one? Experience? Comments?
By jbd5010 in forum Capturing and VCRReplies: 5Last Post: 15th Feb 2011, 20:38 -
Panasonic AG-1980 VCR and PAL vhs
By victoriabears in forum Newbie / General discussionsReplies: 3Last Post: 1st Jul 2009, 14:50
