I downloaded the latest version of Avi2Dvd_Setup_045.exe and after reading and executing the following steps outlined here http://www.afterdawn.com/guides/archive/avi_to_dvd_avi2dvd.cfm all I get is the following log file:
[9:13:02 PM] AVI2DVD Started !
[9:13:09 PM] Type mode : Avi Input
[9:13:09 PM] Output : Dvd
[9:13:09 PM] Encoder Selected : HCEnc
[9:13:09 PM] Start demuxing the AudioStream No.1 ...
[9:13:32 PM] Demuxing of the selected audio finished
successfully !
[D:\AVi2DVD\Avi2dvd_temp\Extracted_Audio.mp3
102613728 Bytes]
[9:13:32 PM] Starts Audio correction ...
[9:13:53 PM] Audio Fixed successfully !
[D:\AVi2DVD\Avi2dvd_temp\Fixed_Audio01.mp3
102613728 Bytes]
[9:13:53 PM] Starts Mp3->Ac3 convertion ...
[9:28:07 PM] Audio converted in Ac3 successfully !
[D:\AVi2DVD\Avi2dvd_temp\AudioStream 1 MP3 2CH.ac3
351816192 Bytes]
[9:28:08 PM] Start creating avisynth script ...
[9:28:08 PM] Avisynth script created successfully !
[D:\AVi2DVD\Avi2dvd_temp\Avisynth_Script_File.avs 163
Bytes]
[9:28:09 PM] Bitrate used : 4500 Kbpps
[9:28:09 PM] Start video encoding ...
[9:28:24 PM] Video encoded successfully !
[D:\AVi2DVD\Avi2dvd_temp\Encoded_Video.m2v -1
Bytes]
[9:28:24 PM] Job NOT Done. There are warnings ... Find at
the log file the 0 byte generated file to focus where exactly
the problem appears
Update....I found this article listed here downloaded the file/program suggested and so far so good. Fingers crossed.
https://forum.videohelp.com/topic355756.html?highlight=avi2dvd
AVI to DVD with soft subtitle and menu with AVI2DVD
By kschang in forum User guidesReplies: 95Last Post: 7th Feb 2011, 17:55 -
Why are my AVI2DVD dvd ISO files TOO BIG to burn onto DVD!?
By Xenogear900 in forum Authoring (DVD)Replies: 5Last Post: 1st Sep 2008, 22:20 -
Problem converting avi to dvd format with Avi2dvd
By bgart13 in forum Video ConversionReplies: 0Last Post: 13th Apr 2008, 17:27 -
Avi2DVD message when loading AVI...."DV DVI Detected"
By geek2330 in forum Newbie / General discussionsReplies: 3Last Post: 22nd Jun 2007, 08:05 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14
