I am creating a DVD that is made up of 12 seperate 3 min Mpegs...I want to create it so
after each one is played , the DVD returns to the menu and I can start the next one
when I want...in other words I don't want the 12 clips to play one after the other...how do I do this?
I hate answering a question with a question, but what authoring app do you plan to use?
Having asked that, I use (and recommend) dvdauthorgui. Turtorials are available. Short explanation...add your titles, click the "nav cmds" button (navigation commands), select each title one at a time, set the end command to return to the menu.
Other tools are available, but I can only tell you about this one as it's what I use.
Oh yeah! Welcome to the forums!Even a broken clock is right twice a day. -
I'm not 100% sure what you're asking, but check this thread to see if its what you want.
https://forum.videohelp.com/topic249265.html#1143278"Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books -
OK...
I have a theater production that utilizes a DVD...instead of starting the DVD at the first clip and stopping/starting it manually, I want to run a clip and when it ends the DVD goes back to the menu...that way I can start the next clip using a icon/button of the clip... -
DVDStyler
Drag clips onto menu, then right click, select properties
Then "jump action" = menu? (return to)
Dvd > options > disable both "create jump pad" + "create empty menu if none exists" > click ok
File > burn dvd > give location to temp dir > check "just generate" > click start ... wait
Remember each button between menus also need a jump action to navigate between them
dvdauthorgui menu question/problem
By tacitus in forum Authoring (DVD)Replies: 7Last Post: 11th Oct 2011, 21:53 -
multiavchd menu question
By mysts in forum Authoring (Blu-ray)Replies: 0Last Post: 27th Apr 2011, 12:12 -
Newbie question: menu and chapters
By cheerful in forum Authoring (Blu-ray)Replies: 0Last Post: 19th Dec 2010, 23:17 -
DVDlab menu question
By rizay in forum Authoring (DVD)Replies: 3Last Post: 12th Dec 2007, 08:54 -
Newbie menu creation question
By dinkob in forum Newbie / General discussionsReplies: 1Last Post: 3rd Sep 2007, 12:49
