hi, is there a way to adjust the volume level without re-rendering? For example, I was working on a vegas 5.0 project. It's only 8 minutes but it takes about 1.5 hour to render it to .avi. I went as far as I could go on the mixer but the .avi volume still seems low. I know "Super" can increase it up to 6db when converting it to other format. Is there a software that provide more than 6db adjustment? Thanks!
I don't know what you are doing in Vegas, but you can easily get more than 6db increase without much effort.
However Vegas isn't the tool to use to increase the volume on a downloaded AVI file unless you are happy to output a new mp3 audio track only, then use virtualdubmod or similar to replace the old with the new. A lot quicker than a needless and inappropriate re-encode.Read my blog here.
Sony trv 18 no internal speaker volume, no headphone volume
By websbymark in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 5th Oct 2009, 12:39 -
adjust the volume
By volam in forum EditingReplies: 9Last Post: 1st Mar 2008, 20:19 -
adjust or normalize volume ac3 5.1 sound of a movie
By volam in forum EditingReplies: 18Last Post: 16th Nov 2007, 14:32 -
how to adjust average volume level to a given dB value? (.wav file)
By zee944 in forum AudioReplies: 5Last Post: 10th Jul 2007, 10:06 -
Adjust audio volume with FairUse Wizard or later
By 2dpikke in forum DVD RippingReplies: 5Last Post: 6th Jul 2007, 00:40
