I apologize if this has already been addressed.
I have a HDTV DVR through Cablevision in New Jersey. I would like to be able to transfer what is captured to DVD. I have a DVD Recorder with a hard drive and I like to record sporting events, mostly NFL games. I can also connect the box to my computer for a direct capture via Firewire to my hard drive. I also use Premiere 6.5 and DVDLab Pro for authoring.
My questions are:
1. I know that I cannot get true HD but is there a way to get a higher rate (say, 720p) on DVD or even DL?
2. What is the best method to use to capture the video with the least dropoff in quality?
3. How can I change the screen resolution when I edit/author?
Thanks for taking the time to read. I look forward to your responses.
Willing To Learn
1. Not in dvd-video format. You can make a blu-ray/avchd on a dvd but it requires then a blu-ray player.
Is there a way to create a DVD from broadcasts capture on my DVR?
Willing To Learn -
If you can put your files on your computer,try loading them in TSmuxer and preserve the 16:9.
Standard DVD only supports 480i/p.
If TSmuxer supports your files you might consider remuxing them to Blueray. You can burn Blueray to standard DVD. If you have a Blueray player and it supports playback from a standard DVD.
HDTV's and DVD's
By pepegot1 in forum DVB / IPTVReplies: 10Last Post: 30th Dec 2010, 19:33 -
Do Samsung HDTV's have an RF antenna connector for receiving off-air HDTV?
By pianopeddler in forum DVB / IPTVReplies: 2Last Post: 6th Aug 2008, 22:43 -
Need al little help getting my new ati hdtv pci card to sense HDTV channels
By MidnightMike in forum ComputerReplies: 8Last Post: 23rd Jul 2008, 03:12 -
Problems with connection with my Panasonic HDTV and Timewaner HDTV box...
By S4one in forum DVB / IPTVReplies: 7Last Post: 2nd Nov 2007, 23:39 -
Enigmavision HDTV - HDTV viewer software for ATSC TV tuner cards.
By gc04 in forum Latest Video NewsReplies: 9Last Post: 7th May 2007, 01:32
