Hi guys.. i recently just bought a ps3 and was converting mkv to be able to play them on ps3 using the software mkv2vob.
my settings are to split the file into 4GB(FAT32) for portable hdd. the rest leave it as default.
so far i encounter 3 problems.
1. They gave me a cyclic disk error.
2. My disk space is always not enough. for a 10gb file convert i have 100gb and the randomly indicated i need more. sometimes during converting, sometimes before converting
3. There was one time when the 10gb vid completed conversion but the end product was a 3.5gb part1 file, was wondering where did the other parts gone to.
sorry for asking so many questions. its my first time.
Cyclic Disk Error usually indicates a problem reading the file. If this is from a DVD then look for scratches and/or finger prints. If it is from a HDD, start looking for a new HDD. This could also be the cause of your other disc issues - size etc. Is this an internal drive, or an external USB drive ? Is it Fat32 or NTFS ? Have you checked your event logs for disk errors ? Have you run a scandisk recently ?
Personally, I would skip mkv2vob and use either TSMuxer or Xvid4PSP. You can use TSMuxer to split the file while it repackages.Read my blog here.
got tsmuxer to complete the mux .. though when playing on ps3 there is sound but no video
#1 here is the file i am playing on the ps3
General
Complete name : F:\converted\spiderman1.split.1.m2ts
Format : BDAV
Format/Info : BluRay Video
File size : 3.72 GiB
Duration : 41mn 24s
Overall bit rate : 12.9 Mbps
Maximum Overall bit rate : 35.5 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 8 frames
Duration : 41mn 21s
Bit rate : 11.7 Mbps
Nominal bit rate : 10.5 Mbps
Width : 1 920 pixels
Height : 1 040 pixels
Display aspect ratio : 16/9
Frame rate : 23.976 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.244
Writing library : x264 core 56 svn-680
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=5 / brdo=0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=2 / deadzone=4,6 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=10457 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / zones=166636,174356,b=0.15 / aq=1:0.3:15.
Language : English
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Duration : 41mn 24s
Bit rate mode : Constant
Bit rate : 640 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48.0 KHz
#2 original file is
General
Complete name : F:\Spiderman.Trilogy.1080p.BluRay.x264-PTM\Spider-Man.2002.1080p.BluRay.x264-hV\Spider-Man.2002.1080p.BluRay.x264-hV.mkv
Format : Matroska
File size : 10.1 GiB
Duration : 2h 1mn
Overall bit rate : 12.0 Mbps
Encoded date : UTC 2007-11-01 18:45:01
Writing application : mkvmerge v2.1.0 ('Another Place To Fall') built on Aug 19 2007 13:40:07
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Video
Format : AVC
Format profile : High@L5.1
Muxing mode : Container profile=Unknown@5.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 1mn
Bit rate : 9 950 Kbps
Display aspect ratio : 1.850
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.208
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=5 / brdo=0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=2 / deadzone=4,6 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=10457 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / zones=166636,174356,b=0.15 / aq=1:0.3:15.0
Language : English
Audio
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Duration : 2h 1mn
Bit rate : 1 536 Kbps
Language : English
Can't get a 1080p DTS .mkv to play on PS3?
By leamingtonspaceman in forum Video ConversionReplies: 6Last Post: 27th Feb 2011, 09:40 -
converting mkv to PS3 using a mac
By carlosian in forum MacReplies: 2Last Post: 15th Oct 2009, 17:07 -
Converting h.264 MKV to Play on PS3/Xbox360
By Startropic1 in forum Video ConversionReplies: 9Last Post: 29th May 2009, 01:34 -
Problem converting mkv to m2ts (for PS3)
By scift in forum Video ConversionReplies: 8Last Post: 16th Dec 2008, 18:22 -
Can a PS3 play mkv x264 files?
By EatMoreChickens in forum DVD & Blu-ray PlayersReplies: 2Last Post: 17th Mar 2008, 09:28
