so i've been having a time trying to convert my vob files into avi or mpegs so i can edit them in Sony Screenblast. The issue i'm having is i'm changing the .VOB to .AVI or .MPG or .MPEG. I guess it changes into an mpeg fine becasue i can watch it. however when i dump it into Screenblast there is no audio. I've even tried converting the avi file to mpeg using TMPGEnc Xpress, but the audio is still not there. what am i doing wrong? why can't i just change the .vob to .avi or .mpeg and get on with life?
Results 1 to 13 of 13
How are you converting the VOBs?
MPEG-2 streams taken from DVD may have AC3 audio, if I remember correctly, so that may also be a problem with some editors.If cameras add ten pounds, why would people want to eat them? -
i am simply using DVD Shrink which creates the vob file. once that is done, i just change the file from .VOB to .MPG.
You could try vob2mpg instead of just renaming. And be sure to remove extra audio tracks in dvd shrink.
If that wont help try convert to avi using winff or avidemux. -
Yeah, I'd suggest using VOB2MPG as well to produce MPEGs from the VOB files, rather than just renaming the .vob files to .mpg. A VOB is a bit more than just a renamed MPEG - there's additional material in a VOB file which your editor may not like.
Are you using Shrink to compress the DVD before editing? If so, why not create MPEGs (or convert) from the original VOBs? Using Shrink to compress will actually lower the quality of the video you're trying to edit.If cameras add ten pounds, why would people want to eat them? -
i'm new at this, so i'm trying not to lower any of the quality. i'm using dvd shrink to get the vob file. next i'm using avi.net, which works great but when i put the avi file in my editing program, only the audio is there. so i have to convert the avi to mpeg using TMPGEnc Xpress. is all this converting messing with the quality? after i have done the editing of the mpegs in screenblast, i render it all to an avi file which i then convert to mpeg through TMPGE and then I use TSUNAMI-MPEG to do the authoring. wow that's alot. is there a better way to do this. i'm using screenblast because i know how to use it.
I've heard of a program called Vidomi that is used as both a video player and a dvd ripper. Maybe you might wanna try that out. It's worked for me. And its sure to work for you. :P
Here's the link to the site:
http://www.vidomi.com/download.php -
Try using VOB2MPG, then take the resulting MPEG and see if it works properly in your editor. Remember, though, that every time you convert, you're losing quality. (Note that VOB2MPG doesn't convert; it 'extracts' the MPEG from the VOB.)
so i used VOB2MPG and it worked very fast, however when i load the mpeg in screenblast or TMPGEnc Xpress i have no audio.
what seems to work, but i'm afraid of lossing quality is: using dvd shrink for the vob files, then avi.net to get the avi. i then convert the avi to mpeg using TMPGEnc. the resulting mpeg is a bigger file than the avi which i don't understand. but i then can load that mpeg into screenblast (which has both audio and video), but again i think i'm losing quality. any suggestions?? thanks for all the help -
Wait. Do you still have the resulting MPEG from running VOB2MPG? Run it through a utility like GSpot or MediaInfo, then post the resulting information or GSpot screenshot here. It probably has AC3 audio, or something similar, and you may just need a codec to be able to process the audio.
Or, at least, does the audio play when you play the MPEG from VOB2MPG? (Especially if you're using a player that doesn't depend on the system codecs, like VLC.)
As for the quality, it's subjective - does it look okay to you? You're re-encoding twice, so technically, you are losing quality both times - but it could still look decent enough for your purposes.
It does sound like you're trying (maybe even unintentionally) to maintain some extra bitrate during the conversions, which is why you're ending up with a bigger file. That may help keep the quality of the file from being degraded as much.
yes, when i load the mpeg file into my edit program, only the video is there. when i play in mpeg in real player, i have both audio and video, and the quality is great. i have the gspot screen print, so hopefully this will pin point what i'm doing wrong. i don't know what any of it means. thanks again for your help
untitled.bmp -
Divx is a poor file format for editing. Many editors don't load it nicely. Even Sony's big boys don't work well with it.
If you are going to go to the trouble of converting the file to AVI, convert it to DV AVI, and you will have no problems editing it.Read my blog here.
vob to avi
By maxone71 in forum Video ConversionReplies: 5Last Post: 5th Oct 2010, 13:51 -
For VOB files to AVI, I use avi.net . . Question
By nhbfan12345 in forum DVD RippingReplies: 4Last Post: 11th Sep 2008, 00:02 -
VOB to AVI?
By fabpozzi in forum Video ConversionReplies: 3Last Post: 5th Sep 2008, 07:21 -
vob to avi
By Johnnylee_hang in forum DVD RippingReplies: 4Last Post: 27th Nov 2007, 15:25 -
VOB to AVI back to VOB
By fatla00 in forum Authoring (DVD)Replies: 23Last Post: 11th Oct 2007, 04:28
