I'm trying to create a motion menu in DVDLab Pro. Basically, I want video and audio to play in the background, and a few buttons and text in the foreground.
The problem I'm having is this: When I compile the dvd or test the menu functionality in DVDLab Pro, all text disappears. The only way I can get the text to remain visible, is to link the text to the movie...turning it into a button. This would not be a problem, however, when I use text buttons, the text always turns out very blurry and hard to read. I thought I could avoid this by using a simple rectangle as a button, and just type some text beside it. It may work, but for some reason the text does not stay visible.
Does anyone out there have any clue as to how I can place text in my menu without it vanishing?
Any help will be appreciated.
Thanks in advance![]()
When are you rendering your motion? Are the text, stills and everything else in place before you render?
It seems I had this problem once before as well, but I'd tried to put the text on top of menu that I'd already made into a motion menu.
Blow out your motion menu and build another with everything you want. Then render the whole thing to a motion menu. See what happens. -
You have to use "Render Motion" if you make a motion menu with text, otherwise text will not be visible after compile.
Use some simple fonts for them to stay sharp. -
Thanks to you both for the help. I was skipping the Render Motion step. Everything is working fine now, and I have my menu just like I want it.
Thanks again
DVDLab Pro ugly text
By optikon2222 in forum Authoring (DVD)Replies: 1Last Post: 14th Oct 2010, 14:26 -
DVDlab Pro: Text set as visible isnīt visible in the result
By Alex89 in forum Authoring (DVD)Replies: 14Last Post: 12th Aug 2010, 07:09 -
Music in your DVD Menu's with DvdLab Pro
By RickyPinxt in forum Authoring (DVD)Replies: 5Last Post: 8th Apr 2010, 17:45 -
DVDLab Pro Menu Structure Questions
By raouliii in forum Authoring (DVD)Replies: 1Last Post: 4th Dec 2007, 21:32 -
DVDLab PRO - Music in Menu
By poutniksantiago in forum Authoring (DVD)Replies: 8Last Post: 15th Nov 2007, 07:28
