I just finished doing this in ffmpeg .... one at at time. A bit of a process and wondering if there's an easier way to do this?
Thank you.
Edit: Have 4 more sets of 15 to do.
VisualHub.
Drag and drop in order into the main window, tell it to create.
sit back, go get lunch.
"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
VirtualDub's File -> Append AVI Segment can automatically append sequentially numbered files.
File -> Open Video File (open first file)
File -> Append AVI Segment (repeat if necessary)
Video -> Direct Stream Copy
File -> Save as AVI -
Well, just finished lunch so I'll have to come up with something else to do. Thank you for this. Looks like learning which application will do which task is an education in itself.Originally Posted by terryj
Wondering if VisualHub has a 'normalizing' function? Guess I'll see shortly.
Like the new avatar.
What is the best/simplest .mkv to .avi (xvid) convertor? (no quality loss)
By loveranger in forum Video ConversionReplies: 11Last Post: 21st Jan 2010, 23:07 -
join several avi files
By hilario in forum EditingReplies: 2Last Post: 13th Nov 2009, 13:49 -
Simplest way to convert and join avi's with different audio streams??
By Lolipop Jones in forum Newbie / General discussionsReplies: 2Last Post: 15th May 2008, 12:25 -
Cant join 2 AVI together!
By GangstaRap in forum EditingReplies: 2Last Post: 25th Dec 2007, 19:41 -
Simplest way to join AVI files with diffferent Sampling rates.
By dagerousdave in forum Newbie / General discussionsReplies: 6Last Post: 15th Nov 2007, 08:03
