Help. I have been trying to convert a downloaded flv file. When I encode this file It can not be read by quicktime. When I go into ffmpegx encoding progress report I get the following:
Encoding started on Mon Jan 19 15:39:57 EST 2009
MEncoder dev-CVS-051126-18:35-3.3 (C) 2000-2005 MPlayer Team
Mac OSX static build for ffmpegX
AltiVec found
CPU: PowerPC
success: format: 0 data: 0x0 - 0x622445
libavformat file format detected.
Unsupported video codec (4)
[flv @ 0x72d500]Unsupported video codec (4)
The end of the report is as follows
[NULL @ 0x710154]picture size invalid (0x0)
/bin/sh: line 1: 3259 Bus error '/Library/Application Support/ffmpegX/mencoder' /Users/ncohen02/Desktop/011609_TV_nudist_video\ copy.flv -oac lavc -lavcopts acodec=mp3:abitrate=128 -srate 48000 -aid 0 -ovc lavc -sws 0 -lavcopts threads=2:vcodec=mpeg4:vbitrate=940:keyint=240:vqm in=2:vqmax=15 -ofps 23.976 -vop scale=640:272 -noodml -ffourcc DIVX -o /Users/ncohen02/Desktop/011609_TV_nudist_video\ copy.flv.ff.avi
I am using an IMac g5 1.8GHz. Any help would be appreciated
Thank you
2th
Results 1 to 11 of 11
Originally Posted by 2thvideo
Then we can see if there are alternative settings that may work.
Case, Thank you for your advice. I used Mediainfo and received the following report. I hope this will help you to solve my problem. Thank you again 2th
text%20report.txt
Thanks Case. But....I must be getting old because my eyesight is failing because no matter how hard I looked I could not find where to check off decode with Quicktime. I have enclosed a screen shot of my ffmepgx options page. Would you tell me which button to check. Thanks. 2th
ffmpegx%20options%20page.pdf
In the screen shot, you are using the mencoder engine for conversion, which doesn't allow for QuickTime decoding (but only mplayer decoding).
In the Video tab, the selected video codec will have name like "MPEG4 [.AVI] (mencoder)".
If you change that to "MPEG4 [.AVI] (ffmpeg)", then the options in the Options tab will be different, and include "Decode with QT".
Convert from MKV to AVI (mpeg-4 codec) + add subtitle to the video file
By kovacic_10 in forum SubtitleReplies: 3Last Post: 19th Feb 2011, 17:38 -
convert flv to mp3-error: unsupported video codec (7)-any remedy?
By lilly333 in forum Video ConversionReplies: 4Last Post: 21st Nov 2009, 14:28 -
Unsupported FLV codec or format
By lovyagin in forum EditingReplies: 25Last Post: 11th Dec 2008, 23:13 -
Can someone please convert this FLV file to avi for me
By hypnoticpimp in forum Video ConversionReplies: 4Last Post: 15th May 2008, 21:37 -
How to convert FLV video file
By MI6 in forum Video ConversionReplies: 4Last Post: 28th Jul 2007, 14:59
