I have tryed to read around in this convertingsection, but I'm afride I'm confronted with a jungel task in converting my mp4 files I have filmed with my sanyo camera with 29.97 fps to a format I can edit for use here in Europ.
What would be a simple way for convorming mp4 29.97 fps to avi, or any format I can import in a 25fps project in Premier Pro CS4 ... ?
gy hd100
I have tryed to import the mp4 29.97 fps file in to P.Pro and export directly to a uncompressed avi file.
The result is a .avi 25 fps file, 10x in file-size.
Can anyone tell me why, and if this resulting file is ok? I just use it, edit it and the result is a 25 fps file that is ok in a 25 fps contekst?gy hd100 -
file size = bitrate * running time.
Select a suitable compression codec and use a lower bitrate.
PP is probably just throwing away 1 frame in every 6 to convert 30 fps to 25 fps. The result is probably jerky. View a smooth medium speed panning shot. You will see 6 little jerks every second. Are you trying to make a DVD? If not, why are you converting the frame rate? -
If I produce a DVD it dont matter what fps I use?
Im making a edit to be watched on tv's here in Europ, probably just from a DVD yes.gy hd100 -
You can make a NTSC 29.976fps DVD as it will work on most european systems.
mixing 1280 x 720 29,97 fps and 1440 x 1080 25 fps in final cut
By perik in forum EditingReplies: 6Last Post: 17th Nov 2010, 23:42 -
how to change fps in mp4 without reencode (maybe ps3 cannot handle 24 fps)?
By redout66 in forum Newbie / General discussionsReplies: 1Last Post: 14th Sep 2010, 05:53 -
Sync 29.970 FPS audio to 23.976 FPS video?
By LCO1971 in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 16:23 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 20:17 -
30 fps flv to 25 fps avi or vcd
By cd090580 in forum Video ConversionReplies: 5Last Post: 12th Nov 2007, 09:35
