I have a Toshiba *tube* HDTV I bought 4 years ago, before they quit making tubes. It works well with DVD and Blu-Ray players. However, when I try to use my HP Pavilion laptop, or my new HV358T media player (it plays vids straight from external hard drive) connected via HDMI to my TV, after about a minute, the blacks turn green. The only way to fix this is to turn down the brightness on the TV, but then everything is dark. I have played the same movie from my Panasonic Blu-Ray player, and from the HV358T media player, and this is always the result: The Blu-Ray player looks great, the HV358T (and my laptop) provide poor quality signals. My question is: Is there something built into the disc players that compensates for the tube TV, that my laptop and HV unit do not have? If so, can I buy a device to fix this problem? Thanks for any help! Tim C
It sounds like a TV failure or error. HDMI digital (16-235 or 0-255) should not be able to overdrive the TV.Originally Posted by heticu
Have you tried an analog component connection from the Blu-Ray? Does the problem still exist?Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Problem solved. Apparently, HDMI was cutting-edge technology when my Toshiba TV came out in 2004. They did not get the conversion units correct. I switched to composite cables (Y, Pb, Pr) and the problem went away. In fact, I think the color is a tad bit better using these than the HDMI signal from my disc player. Thanks for the input.
Turns black and white
By dadihawks in forum Newbie / General discussionsReplies: 1Last Post: 1st Oct 2011, 06:59 -
LCD TV, when playing DVD turns green after 20 min of play...????
By boston_012 in forum Newbie / General discussionsReplies: 12Last Post: 9th Aug 2009, 22:11 -
Vegas rendering problems, clips with increased speed turns out black
By sebaa in forum EditingReplies: 0Last Post: 10th Feb 2008, 15:24 -
Screen turns green
By boysha in forum Newbie / General discussionsReplies: 2Last Post: 31st Dec 2007, 14:46 -
green picture!
By w50cfc in forum DVD & Blu-ray PlayersReplies: 2Last Post: 25th Jun 2007, 03:39
